Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2018 2.0 issues
Old Jan 5, 2021 | 10:11 AM
slash31938's Avatar
slash31938
2018 2.0 issues
Wife has a 2018 escape with right at 64k on it. Had a misfire code so I put new coils and plugs on it due to the mileage and just to make sure they were all good. Also around the same time i noticed the coolant bottle was low, so i topped it off. The code came back, and i noticed that the coolant was low again. Ive read about these having coolant loss issues in the heads, and that also causing a misfire code. I know there is a TSB for the work, but that the warranty is only to 60k miles. Does anyone know if ford will touch it under a "goodwill" warranty for that TSB or are we looking at out of pocket expenses? Thanks for your time.
Old Jan 6, 2021 | 07:36 PM
cdchase's Avatar
cdchase
TSB
I have a couple of TSB's on my Explorer. The service department told me that those TSB's were an extension of warranty. Call the dealership and ask them about the TSB. Check to see if the reservoir is pressurized while running. That is an indication of compression leaking into the cooling system. Check the oil dipstick and the fill cap. See if the oil looks milky and/or overfilled. That's an indication of coolant leaking into the oil. Check the exhaust. Blue smoke is oil burning, whitish smoke with a sweet smell is coolant leak into the exhaust.
Old Feb 11, 2021 | 02:51 PM
merlynr's Avatar
merlynr
My daughters 17 esc 2.0 had engine failure at about 60k miles and shop said it was a bad block and dealer replaced it but she traded for a lincoln while waiting.
Mestrada253
6.7L Power Stroke Diesel
Jul 18, 2020 02:42 PM
NorthCarolinaExpy
Feb 8, 2018 12:06 PM
Lofide20
1997 - 2003 F150
Jan 18, 2017 02:09 PM
Ensign Pulver
6.4L Power Stroke Diesel
Jan 5, 2015 08:03 PM
MSUslacker
Dec 26, 2010 04:23 PM
