overdrive tranny?
Old Oct 25, 2003 | 03:48 AM
willowbilly3's Avatar
willowbilly3
overdrive tranny?
I don't stray out of the 67-72 camp much but I thought this question belonged here. I found an 80-86 style pickup in the junkyard with a manual (o/d ? ) transmission that I am not familiar with. I could only see down through the shifter hole and it had a single shift rail running in the rear of the main case. I have seen the top loader style o/d with the old style car type shifter and the rather rare o/d with a top tower shifter but never a manual with a rail style shifter. Any clues? Thanks
Old Oct 26, 2003 | 01:02 AM
desperado_18_2000's Avatar
desperado_18_2000
it might be an SROD Single Rod Overdrive. I don't know anything about them. But thats probably what you are looking at.
Old Oct 26, 2003 | 08:12 AM
willowbilly3
I kind of thought it might be a SROD but I have only ever seen them in Mustangs, and I couldn't remember about the shifter location but this one was on the outside of the case and I thought the SROD was inside the tail housing.
Old Oct 26, 2003 | 12:25 PM
bremen242's Avatar
bremen242
yeah, and stay away from anything manual&overdrive that came in ford truck, unless it is a ZF5 or 6.
Old Oct 26, 2003 | 06:28 PM
willowbilly3
or a T-85
Old Oct 26, 2003 | 07:54 PM
bremen242's Avatar
bremen242
whats a T-85?
Old Oct 27, 2003 | 12:13 AM
willowbilly3
A Borg-Warner T-85 was a cast iron 3 speed with overdrive. If you aren't familiar with the system, it has the overdrive built into the tailhousing and could actually use it in each gear except it had a governor that locked it out below 33 mph so it really couldn't be used in 1st, but was actually a 6 speed. These were last used in 1972 and were column shift. Way cool
Old Oct 27, 2003 | 05:25 PM
bremen242's Avatar
bremen242
No kidding.. that sounds awesome! not the the column part, but that is almost like a gear venders unit..
