Cutting conners Do or Do Not
Old Jan 4, 2021 | 07:08 AM
killjoykarl's Avatar
killjoykarl
Is there any downside to mounting a light this way. Cutting the grill while it’s attached just curious on some thoughts Thanks.
Old Jan 4, 2021 | 07:41 AM
2020STX250's Avatar
2020STX250
Originally Posted by killjoykarl
Is there any downside to mounting a light this way. Cutting the grill while it’s attached just curious on some thoughts Thanks. https://youtu.be/u79JxyG95mM
it looked like the cut all of the bottom retainer snap in clips off when they put in the upper bar. Not sure how much that would cause the grill to shake around and make a bunch of noise.
Old Jan 4, 2021 | 07:44 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I did it. Been running it that way for over a year...no problems!
Old Jan 4, 2021 | 07:58 AM
killjoykarl
Did you remove the grill or install with grill on?
Old Jan 4, 2021 | 06:21 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I removed my grille to cut it. I see no reason why you couldn't do it on the truck like they did in the video though.
Old Jan 5, 2021 | 08:44 PM
SteveOF350_SCREW's Avatar
SteveOF350_SCREW
I used an oscillating tool, didn’t remove the grill. Still super solid.
Old Jan 5, 2021 | 09:02 PM
mcmurm's Avatar
mcmurm
Wonder if this is possible doing the same with a 2021 Platinum grill?
Old Jan 5, 2021 | 09:37 PM
honda250xtitan's Avatar
honda250xtitan
OR mount a baja designs 10" ONX6 light bar in the bumper. use their upfitter harness. zero hacking on your 70k truck. :shrug:
Old Jan 5, 2021 | 10:22 PM
mcmurm's Avatar
mcmurm
I'd thought about settling for that too, but I think I'd prefer more light output.
Old Jan 5, 2021 | 10:41 PM
SteveOF350_SCREW
the 40inch curved bar from rough country works great. It’s like switching on a small star on the front of the truck. Turning it off makes even the regular high beams seem like parking lights!
Totally worth the “hacking”
nathan_2017
Nov 22, 2017 09:28 PM
jniolon
Aug 16, 2016 09:19 PM
Methodic Menace
Feb 27, 2016 05:17 PM
ccllud
Jun 17, 2014 11:17 AM
fordzrule
Mar 10, 2002 10:54 PM
