Conditioning module gurgling sound
Old Jan 3, 2021 | 06:30 PM
Aaron2012f250's Avatar
Aaron2012f250
This is a 2012 f250 6.7 fx4 lariat. I had some problems a couple nights ago, the truck went to zero boost while towing, even though I could hear the turbo, and someone mentioned refueling. So I checked what i could and found i can hear a gurgling sound at the frame mounted pump. Before doing anything I drove it and boost was back,weird. But after two complete filter changes I still have a gurgling sound at the pump, like air in the lines. Zero chance it's the filter install. Any help is much appreciated, thanks.
Old Jan 4, 2021 | 03:02 AM
Overkill2's Avatar
Overkill2
That could be air in the DFCM. Did you do enough key on engine off cycles to purge the system of air? What you describe is what I hear when I do a filter set change. I go overkill and do 12 KOEOff cycles to rid the fuel system of air. Someone with more knowledge will chime in later I'm sure.
Welcome to FTE.
Old Jan 4, 2021 | 04:40 AM
Just Strokin's Avatar
Just Strokin
I am wondering if the cup was screwed on til the stops meet. There is a stop on the module and a stop on the cup. The cup should be screwed on til both meet.
Also, did you make sure the o-ring on the yellow plug was in place and lubricated when you screwed it back in.
Old Jan 4, 2021 | 09:16 AM
dirthawg's Avatar
dirthawg
Check the bowl for cracks. Like Larry mentioned it's possible the yellow drain plug is letting air in.
IIRC another user here had an issue with air getting in the DFCM even though he did everything correctly, it turned out to be a bad yellow drain plug.
raymondgajewski
EcoBoost (all engine sizes)
Oct 26, 2017 04:29 AM
61 uni
Nov 28, 2009 10:19 PM
Chorizo520
25
Apr 3, 2007 11:10 PM
Don the Tile Man
Nov 19, 2006 04:09 PM
408w
17
Sep 25, 2006 01:04 PM
