Fuel Additive Thread
Old Mar 15, 2021 | 12:56 AM
  #46
Wes444's Avatar
Wes444
Originally Posted by MountainManRobb
So it is your opinion that the Hot Shot Secret products do not help with lubricity? I personally have never experienced any kind of MPG improvement from "every tank" products of any brand.
I notice a mpg bump when I put in 2oz of their everyday EDT (small container, orangish color) at fill-ups. When towing heavy I notice it with their Diesel Extreme (larger jug, red color)
Old Mar 15, 2021 | 06:30 AM
  #47
MountainManRobb's Avatar
MountainManRobb
The EDT is what I have been running, until lately, in my truck. I have not used the Extreme when towing though. It seems like I read somewhere they don't recommend that because it causes a slight increase in EGT's, or something to that effect.
Old Mar 15, 2021 | 01:53 PM
  #48
Paul_R7.3's Avatar
Paul_R7.3
Lots of great reading here for an oil nerd like me. On my way to pick up a gallon of Optilube XL and a quart of Optilube Boost. Living in California where minimum cetane spec is 53, I really don't need cetane boost so just be getting a little for when I travel out of state. FWIW, I always fill up with genuine top tier fuel.
Old Mar 15, 2021 | 01:54 PM
  #49
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Awesome! Let us know how you like it.
Old Mar 15, 2021 | 02:00 PM
  #50
ESwift's Avatar
ESwift
CNCFAB
I ran stanadyne performance for years, always seemed to work well. The other year I switched to optilube xpd I notced more black smoke, ran it for a year till supply was out and went back to stanadyne performance, just for giggles did optilube for a few tanks last year, again more smoke, this time on both trucks(didnt have 2 trucks before), so I will stick with standadyne performance.
I did no scientific research in this just butt dino and rear view mirrow watching:-)
Old Mar 15, 2021 | 02:05 PM
  #51
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Back when the 7.3L was new, the only diesel fuel additives that International and Ford recommended, in writing, were branded Stanadyne, with the exception of the Ford marketed PM-22 and PM-23 additives.
Old Mar 15, 2021 | 02:09 PM
  #52
ESwift's Avatar
ESwift
CNCFAB
Didnt know that.
My work truck I have had for a long time was bought from a good friend. He is a top notch diesel tech and fabricator. He sent half a case of the stanadyne with me and said to use it, so I did. I always figured if he recommended it, it must be good. At that time I was just learning to change my own oil. It is funny now, cause he calls me with 7.3 related questions :-)
Old Mar 15, 2021 | 02:25 PM
  #53
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Are you able to tell us which current formula available resembles the Stanadyne recommendation of yesteryear the most?
For reference: https://promo.parker.com/promotionsi...us/en/products
Again, I ran Stanadyne Lubricity for years based on the spreadsheet noted above and the cost involved based on buying in bulk. I never really noticed a difference, but was not really paying that much attention to it either. It was just something I did when filling up the OEM and auxiliary tanks.
Old Mar 15, 2021 | 03:24 PM
  #54
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
For reference: https://promo.parker.com/promotionsi...us/en/products.
Stanadyne has changed corporate hands about 4 times since Ford first went on the record in 1994 recommending Stanadyne as a fuel conditioner. Even the founder and namesake of the parent company that now owns FTE used to own Stanadyne, for about 10 years. I cannot speak to any changes in Stanadyne formulas or their correlation with current product marketing names. I can only point out some of the Stanadyne products that Ford and International have recommended, in writing, under warranty, to the exclusion of any other diesel fuel additives, with the exception of the additives branded by Ford (PM-15, PM-22a, PM-23a).
Note: I forgot to underline the sentence in the screen shot above "Other brands of conditioners or additives are not recommended."
In subsequent writings, and in particular when the 1999 up 7.3L Super Duty, Ford and International recommended "Stanadyne Performance Formula" with the blue label. I purchased Performance Formula by the case when I bought my 2000 7.3L, after attending a diesel training session taught by the field service engineer at International, if that gives you any idea how strongly Stanadyne was recommended back then.
The real concern that Ford and International had was the potentially harmful aspects of some of the ingredients found in other diesel fuel additives on the market at that time, which they had tested.
For the next 10 years, I regularly dosed each fuel tank with Stanadyne Performance Formula. I kept a half gallon bottle, with a turkey baster, in one of the side boxes of the truck, near the fuel filler. I cannot report that Stanadyne was better or worse than other fuel additives, because I didn't try other fuel additives. I let Ford and International do that testing for me, and simply followed their recommendations.
I then bought Ford's PM products (by the gallon, in the metal can) when my source for Stanadyne at wholesale pricing dried up.
Additional Stanadyne products I've seen mentioned in Ford TSBs are the Lubricity Formula, and an anti gelling (although I do not recall the current trade name "Winter 1000" ever being mentioned).
The Performance Formula (blue label) covers lubricity, anti-gelling, and cetane improvement in one shot.
California diesel fuel was reformulated about a year before the rest of the nation was required to adopt ULSD.
Old Mar 15, 2021 | 03:50 PM
  #55
ESwift's Avatar
ESwift
CNCFAB
I buy it by the case(actually usually 2 cases). One of these containers treats 30 gallons, about what it usually takes to top up my tank, which is very convenient.
Old Mar 15, 2021 | 08:42 PM
  #56
MountainManRobb
I have run the Stanadyne in a Duramax, but not my 7.3. The guy at the local parts store I frequent is a fan of Stanadyne in his 6.7 PS, and I guess has been using it for several years in different diesels.
Old Mar 16, 2021 | 09:43 AM
  #57
beachcamperf250's Avatar
beachcamperf250
Which FPPF product was used for the study?
I see a ton of them listed on the website: https://fppf.com/product/
Old Mar 16, 2021 | 09:55 AM
  #58
Sous's Avatar
Sous
FTE Emeritus
Line #16 in the chart states "FPPF Lubricity Plus Fuel Power" and page #8 (item #16) states the same.
FPPF Lubricity Plus Fuel Power link
Line #3 in the chart states "FPPF RV, Bus, SUV Diesel/Gas Fuel Treatment" and page #5 (item #3) states the same.
Since the treatment listed in line #3 is not on the FPPF product page, I can only assume it was discontinued. I performed a brief search for it, but I was not able to identify that product available for sale.
I hope this helps answer your question.
Old Mar 16, 2021 | 11:47 AM
  #59
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I would not use "FPPF Lubricity Plus Fuel Power" period.
FPPF has not released an MSDS for that product. I would need to see that first, to make certain that there were no alcohols in it.
FPPF can't even correctly spell what testing was "parformed" (sic) in FPPF's product marketing materials.
FPPF has released an MSDS on their other products, but unlike Stanadyne, which fully discloses the elemental concentration percentages and has nothing to fear or hide, FPPF, on the other hand, does not disclose the concentration of the regulated ingredients.
The FPPF product "Lubricity Plus Fuel Power" appears to be a blend, where FPPF has added "lubricity" to their Fuel Power product. So let's take a look at the MSDS of the FPPF Fuel Power product.
FPPF Fuel Power SDS
Only one ingredient listed. Glycol Ether. (Dipropylene glycol monomethyl ether). Since Glycol Ether is the only listed active ingredient (where FPPF obfuscates the concentration as a so called "Trade Secret"), we are left to assume that the main ingredient is glycol ether.
Let's get some help in understanding what glycol ethers are....
The initial materials for the preparation of glycol ethers are propane oxide (giving propylene glycol ethers) and alcohols.
Glycol Ether products are produced through continuous processes of selectively reacting an alcohol and ethylene oxide.
DOW Chemical Glycol Ether Selection Guide
Now let's take a look at the MSDS of Stanadyne Performance Formula for comparison...
Stanadyne Performance Formula MSDS
Of note, on the Stanadyne MSDS, nine (9) ingredients are listed, including percentage range of concentration by weight of each ingredient in the composition, comprising the entirety of the product All percentages add up to more than 100%... no "trade secrets", no hiding, no magic black genie bottle hocus pocus bs). All CAS #'s are disclosed by Stanadyne for each ingredient, whereas FPPF fails to disclose the CAS # for the single and only ingredient identified in their Fuel Power product SDS.
There is a very small percentage (between 2 to 4 percent) of Ethylene glycol monobutyl ether in the Stanadyne product, presumably as a de-icing agent. The glycol ether links provided immediately above will help distinguish how this is different from the glycol ether in the FPPF product.
@MountainManRobb mentioned using Stanadyne in his Duramax, a couple of posts up. So let's compare what General Motors has to say about diesel fuel additives they recommend, versus what Ford says...
___________________________
From the Duramax Diesel Engine Supplement (Page 5-2)
Diesel Engine Fuel
Notice: Diesel fuel or fuel additives not recommended in this manual could damage your fuel system, fuel-operated heater (FOH) (Van models only) and engine. Your warranty would not cover this damage. And:
  • Diesel fuel that has been mixed with engine oil or automatic transmission fluid could damage your engine and emission controls.
  • Aftermarket diesel fuel additives are not tested by General Motors. Some additives, particularly those which contain alcohol or water emulsifiers, may damage your fuel system. If you believe that unique circumstances call for a fuel additive to be used, consult your dealer for advice.
  • If you ever run out of diesel fuel, it can be difficult to restart your engine. To avoid all this, never let your tank get empty.
If gasoline is ever accidentally added to the fuel tank, to avoid severe engine damage, do not run the engine until the fuel tank can be drained.
General Motors Corporation
Bulletin No.: 03-06-04-017B
Date: September 07, 2005
INFORMATION
Subject:
Information on Diesel Fuel Additives
Models:
·2006 and Prior Light duty and Medium duty Trucks
·2006 and Prior Isuzu Commercial Medium Duty Models
·2006 and Prior HUMMER H2
with 6.5L, 6.6L Duramax®, 7.2L or 7.8L Diesel Engine (VINs D, F, P, S, Y, 1, 2, 3 – RPOs L65, L49, L56, L57, LB7, LLY, LBZ, LC8, LG4)
Supersede:
This bulletin is being revised to add model years, enhance the content and add GM diesel fuel conditioner. – Please, discard Corporate Bulletin Number 03-06-04-017A (Section 06 – Engine/Propulsion System).
Important:
The use of diesel fuel additives is not required or recommended for the 6.5L or the 6.6L Duramax® Diesel engine under normal conditions. The filtering system is designed to block water and contaminants without the use of additives. However, some customers may desire to use fuel additives to improve the characteristics of available diesel fuels.
Water Emulsifiers and Demulsifiers
If the customer desires to use a fuel additive, care must be taken in its selection. There are two common methods that fuel additives use to cope with water in the fuel. One method is through demulsification of water in the fuel. This method causes water particles to combine together to form larger particles, which drop out of suspension. This allows the fuel-filter/water-separator to separate the water from the fuel as it is designed to. The other method of coping with water in the fuel is through emulsification . This method, often using alcohol as the emulsifier, keeps water particles suspended in the fuel. Emulsification of water in the fuel can allow water to get past the fuel-filter/water-separator, in most cases causing damage to the fuel system.Only alcohol free water demulsifiers should be used in General Motors diesel engines. GM Diesel Fuel Conditioner®, P/N 88861009 (in Canada 88861038) or both *Racor Power Shot® and *Stanadyne® diesel fuel additives are alcohol free and utilize water demulsifiers to cope with water in the fuel. Other brands may be available in different areas; be sure that they clearly state that they are alcohol free demulsifiers before use.
* We believe these sources and their products to be reliable. General Motors does not endorse, indicate any preference for or assume any responsibility for the products from these firms or for any such items which may be available from other sources.
Common Diesel Fuel Concerns
Fuel Waxing/Icing
Fuel distributors blend #1 and #2 diesel fuels for seasonal requirements in a particular region. No other blending of fuels is recommended. However, a customer may desire to use a winter fuel additive to prevent fuel waxing or icing during extreme cold snaps. If a winter fuel additive is to be used, it should not contain alcohol or other water emulsifiers that may compromise the water removal effectiveness of the fuel filtering system.
Bacteria and Fungi Growth
Bacteria and fungi growth can occur in diesel fuel when there is water present, especially during warmer weather. The best prevention against bacteria and fungi growth is to use clean fuel that is free of water. There are diesel fuel biocides available that are designed to kill bacterial growth in the fuel system. However, the dead bacteria can still cause blockages throughout the fuel system. If bacterial growth is found in the fuel system, the proper method of removal is to flush the fuel system using the service Manual procedures, replace the fuel filter element and refill the tank with clean diesel fuel. If a customer desires to use a biocide after flushing the fuel system, it should not contain alcohol or other water emulsifiers.
Low Cetane Number
The cetane number is one indicator of a diesel fuel's ability to ignite. There are may indicators of overall fuel quality such as cleanliness, specific gravity, volatility, viscosity, detergency, corrosion inhibiting abilities, and lubricity. Increasing the cetane number alone is not a fix for poor quality fuel. Additionally, increasing the cetane number beyond the engine's requirements will not increase performance. However, the cetane number of diesel fuel is not always consistent and some customers may desire to use a cetane improver to ensure full performance of their engine. If such an additive is to be used, it must not contain alcohol or other water emulsifiers.
Poor Lubricity
The 6.5L diesel and the 6.6L Duramax® Diesel engines are designed to operate on today's low sulfur fuel without the use of additives. A fuel additive designed to increase lubricity is not a fix for poor quality or contaminated fuel, but some customers may desire to use a lubricity additive to aid in the longevity of their fuel system components. If such an additive is to be used, it must not contain alcohol or other water emulsifiers.
Fuel Source Issue
If a vehicle is properly maintained but has fuel contamination issues, consider obtaining fuel from a different source. Purchasing fuel from a high volume fuel retailer increases the chance that the fuel is fresh and of good quality.
Part Number___________________Description______________________
88861009(in Canada 88861038)_ Conditioner, Diesel Fuel (11 oz)_
And finally, let's see what Ford says about diesel fuel additives for the current diesel engine that Ford produces:
Diesel Fuel Additives: It should not be necessary to add any aftermarket additives to your fuel if you use a high quality diesel fuel that conforms to ASTM industry specifications. Aftermarket additives can damage the fuel injector system or engine. Use Motorcraft® cetane booster or an equivalent cetane booster additive if you suspect fuel has low cetane. Use Motorcraft® anti-gel & performance improver or an equivalent additive if there is fuel gelling. Do not use alcohol-based additives to improve cetane quality, to prevent fuel gelling or any other use. The use of alcohol additives may result in damage to the fuel injectors and system. See Engine Specifications (page 434). Your warranty may not cover repairs needed to correct the effects of using an aftermarket product that does not meet Ford specifications in your fuel.
Old Mar 16, 2021 | 12:09 PM
  #60
beachcamperf250
Wow, interesting that the FPPF product was high up in the results even if it is not good to use.
