Isn’t that part of the damper? That would bug me too much not to at least try. Maybe you can get the puller in there without removing the radiator. Even if it does need to come out it isn’t that time consuming or difficult.
Yes, the engine will run fine....as well as a bright Check Engine Light all the time.
Nothing detrimental will happen with the missing sensor. If something else goes wrong you will never know unless you periodically check for codes.
Thank you, that was what I was thinking but a confirmation is great.
I am going to pull the parts off the old engine and put them on a shelf. If I am ever in there again I will toss them on. I do work a ton of hours and am real short on free time right now.
I ran my '96 351W without the correct balancer (no stator ring) for three years. Constant check engine light, no easy way to know which cylinder is misfiring (if there was a miss). Seemingly that was it. I swapped in the correct balancer (note: didn't remove the radiator or fan), reset the PCM, and the code was gone. The weird part is, I had been chasing a driveline slack sensation for a long time, and once I remedied the misfire sensor issue & reset the PCM, no more driveline slack feeling. Strange no doubt.
For your use, I would keep the 1 year only parts on the shelf. It's not a big deal to swap them in if you opt to do so. But if you get rid of those parts, don't expect to find them again (especially the balancer).
