Sponsored by: Real Truck
Check Engine Light - Code: P220F
Old Dec 16, 2019 | 04:39 AM
phydeauxman's Avatar
phydeauxman
Retired Livin the Dream
I have a 2014 F250 6.7 that has 49,000 miles on it. Recently the check engine light came on and when I read the codes with my reader, it was P220F: NOx Sensor Heater Control Circuit Range / Performance (Bank 1 Sensor 2). Does anyone have any experience with what would cause the code? Is it sensor on the exhaust going bad (like an O2 sensor on a regular gas vehicle)? If so, where is the sensor located?
Old Dec 16, 2019 | 05:28 AM
seville009's Avatar
seville009
this shows diagrams and pics
https://www.ford-trucks.com/forums/1...ensor-2-a.html
Old Dec 16, 2019 | 05:52 AM
phydeauxman
Originally Posted by seville009
Thanks for the link. I am assuming since mine is saying Sensor 2 that it is the 12 sensor in the diagram and would also be referred to as the "downstream" sensor. I am wondering if the sensor can be removed and cleaned. I recently had an exhaust leak just aft of that sensor caused by a couple of broken bolts. I also have notice reduced mileage (by like 3 miles per gallon) in the past few months.
Old Dec 16, 2019 | 06:56 AM
Djosbun's Avatar
Djosbun
That is pretty low miles for an oxygen sensor to fail, although it is perfectly possible. I would first check the connector from the sensor to the harness. Make sure it or the wiring is not damaged. Unplug the connector and make sure both all contact points are clean- no crudites or any crud inside.
Keep in mind that an O2 trouble code doesn't always mean the sensor is bad. I helped a friend diagnose a recurring O2 code and the problem was his ECU (which sicked for him but resolved his issue).
-- Dave
Old Dec 16, 2019 | 07:14 AM
phydeauxman
-- Dave
Thanks for the additional info. What additional steps did you take to help your friend diagnose the problem? I have an extended warranty on my truck which would cover the ECU but not the sensor.
Old Dec 16, 2019 | 09:39 AM
dirthawg's Avatar
dirthawg
Maybe this will help? From the 6.7L service manual.
RD Pinpoint Tests
File Type: pdf
Old Dec 16, 2019 | 10:07 AM
phydeauxman
RD Pinpoint Tests
Great info...thanks for sharing. Going to try and clean mine first before replacing.
wikdwest
Jul 19, 2014 12:12 AM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
jellybean66
Mar 1, 2009 01:23 PM
