Just For Fun!
Old Jan 7, 2021 | 10:35 PM
65f100_352's Avatar
65f100_352
Originally Posted by Deerhunter4
My crossmember has already been moved once when the PO swapped in the 460 since the truck originally had a 400. I’m guessing the bigger 460 required it to move back some. I’ve also read that a ZF5 should be pretty close to a C6 and some have been able to use the factory driveshafts. My luck everything will be off just enough to cause a lot of work! If I run across the swap thread I found I’ll post up a link.
I wonder if your truck had a manual in it or something, because when I swapped the 460 into my truck, I didn't touch the transmission, just had to use an adapter plate to mount the 400 engine mounts to the 460 block.. hindsight, I could have just made them myself, but i was just out of high school when i did it lol..
We shall see how far off the zf5 is compared to the c6, knowing my luck, I'll have to modify a bunch lol..
agsent
Dec 19, 2010 09:58 PM
greenwoodford
May 21, 2010 12:32 PM
77'F-150Mudder
Engine Swaps
Apr 7, 2010 01:31 AM
SCOOBYMEISTER
Jan 23, 2008 11:56 PM
BigBlockF-250
Oct 14, 2005 11:56 AM
