Anyone upgraded fuel pumps?
LINK PREVIOUSLY PROVIDED HERE ( Company withheld information, issue not resolved)
I read every line on this thread and thought I needed to up the wire size. I did some more digging and here's what I got; These pumps only pull 12.5 amps. The relay is 20. I bailed on the wire size increase. I wired in a 15 amp fuse at each tank. So far so good. They are MUCH quieter than I was expecting. I would put them right at stock (quieter if yours are dying). Check it out.
Neighbors starting to think I'm crazy
Cleaned up pretty good
Dogs aren't sure how they are supposed to ride on that.
Carb spray, compressed air, and a vacuum BEFORE you pull that pump!
Pic out of order, but you get the idea.
I torch soldered and heat shrunk both lines. Factory was only the hot.
New unit was a great fit.
I figured these couldn't possibly hurt.
This will be my test piece. It's soaking in gasoline as you read this. The second I don't like how it looks in the jar, I will reassess.
I intended on a new seal but the parts store only had one and wouldn't sell separate from the metal lock ring. Old seal was soft as could be so I saved $25 and cleaned up the old one. Use a little oil to promote seal and maybe swell a little.
The paint. always have to paint. Never on wires or liquid lines, that's just not tasteful.
Two layers of 20 mil tape under each bed mount hole. I can't stand the the constant erosion of my precious bed supports and being constantly reminded by the friction noise.
I will update you guys if anything dies an early death or they don't pump as advertised. These were laying the foundation for this
Don't forget to test it all before the bed goes back on.
Last edited by Bignasty2; Mar 20, 2021 at 06:35 PM. Reason: Pumps developed noise, got the runaround, link removed
And here I thought they were thinking... “Finally, we get to ride in the cab!”... lol.
Looks nice, frame cleaned up very nice, the condition of your southern trucks always amazes me! That looks like quite the engine you have for it too!
Cheers, 🍻
Is/was a 5.8 KB available only for a 5.8 GT40/Lightning lower?
I didn't run any new wires or relays. No issues. The Aeromotive pump is a lot quieter than the stock ones were as well.
Glad to hear you got it all sorted out. Looks like a job well done.
What is the black square with four bolts on the back of cab, in the left on the picture?
My old 94 had the holes plugged, but nothing there. My flareside does not have holes at all, nothing.
There has been previous discussion on this forum about these. There doesn't seem to be a rhyme or reason as to why certain cabs got them. You can find any cab configuration, with any engine, and any trim level with or without it. Seems like they just put them on at the assembly line when they felt like it.
I would like to verify the stock pump output other than in link #1 so if anyone has that info could you please post a link to it or the specs of it. The point of this is to find a OE pump that flows more and right now its looking like the 95-96 Explorer pump puts out a little more than the OE pump in our trucks.
Edit. I added the Airtex fuel pump link at the bottom.
https://www.f150online.com/forums/pr...mp-rating.html
https://www.highflowfuel.com/product...q_f150~zp_5-8l
https://www.rockauto.com/en/parts/ai...fuel+pump,6256
https://www.rockauto.com/en/moreinfo...k=293230&jsn=3
https://www.tascaparts.com/search?se...Pump&ptid=6256
https://www.rockauto.com/en/catalog/...fuel+pump,6256
https://www.rockauto.com/en/moreinfo...060&cc=1122196
https://www.rockauto.com/en/moreinfo...1122196&jsn=22
https://www.advancedconverter.com/un...llons-per-hour
https://airtexasc.com
