302 poor mileage/performance
Old Nov 15, 2000 | 09:03 AM
gwp's Avatar
gwp
I have a 95 F-150 2WD with the 5.0L & E4OD. I had an 89 which had more grunt than this one. I use it for towing and barely manages a 20' ski boat where the 89 could take on both the ski boat and an cabover camper. I hear from non-CA owners of the 5.0L package that 18-19mpg is realistic on the freeway. I have tried everything external to the engine except a chip and only get 15mpg (and anemic torque below 2000rpm). K&N, 3" CAT back, JB shorty hdrs, MSD-6A. What has Ford done different for the CA engines? What can be done to get higher mileage and/or a little more power below 2500rpm?
Old Nov 15, 2000 | 11:13 AM
PAUL_2's Avatar
PAUL_2
Im sure the added emissions equipment impair the engine . If you are doing a lot of towing , hauling then rear end gear changes is probably the best way to go . Your 89 may have had lower gearing ?
Old Nov 15, 2000 | 01:58 PM
gwp's Avatar
gwp
The 89 started out with 3.50 gears on stock P235-75R15 tires. Then the gears changed to 4.10 AFTER the tires changes to 10.00X31. So, for a while the 1" larger diameter tires were on the 3.50 gears. The 95 has 3.50 gears with P275-60R17, about 1" larger dia than the stk P235. So, all things near equal, the 95 302 is really choked.
Does CALIF need more, or more restrictive emissions specs, than Oregon? The 18mpg of non-Calif 302's is with the same (95-96) model years. What can be done that has a CARB EO# or pass the sniffer tests?
Thanks.
Old Nov 15, 2000 | 02:10 PM
Pastmaster's Avatar
Pastmaster
How many convertor's does it have? I know that California' trucks have really restrictive exhuasts, which most likely gives you the problem, Also, you should have the Mass Air efi system, which I believe doesn't get the mileage of a speed density system.,
BTW, my 93 get's about 18 now, I got 23 during the summer of 1999.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
1989 F-150 4x4 302 auto
toydestroyer1(No Email Addresses In Posts!)
Old Nov 15, 2000 | 07:39 PM
jasons's Avatar
jasons
Old Nov 16, 2000 | 02:57 AM
jams3's Avatar
jams3
so if i understand wright the cal trucks are
more are a little under powered then non
cal trucks the reasen that i ask is i bought
a f150 that was purchest in navada and it seams
real peppy for a 302 when i had the tranny serviced i road with the tech he asked if i
had a 351 i toled him no it was a 5.0
he seemed suprised.
so my quistion is when i have my truck serviced or when i buy parts should i tell them that is a
non cal truck? i do live in so cal
thanks
marc
conejo_guy
Mar 26, 2013 01:50 PM
largefries
2004 - 2008 F150
Apr 6, 2012 08:51 PM
Pinkster1
16
Feb 4, 2005 07:56 AM
towing_joe
Jun 1, 2001 12:16 PM
kb
1978 - 1996 Big Bronco
Jul 21, 2000 07:47 AM
