2015-2019 to 2020 ECM Reprogram
Old Dec 27, 2020 | 05:17 PM
Ingotsilverf350's Avatar
Ingotsilverf350
Query for those techies who might know the answer...
I have a 2020 F-250 with the 6.7 PSD.
I'd like to retain my truck's original ECM in stock form for warranty/whatever other reason.
I'd also like to have an ECM to experiment with, maybe even plug-in and use if I take the truck off-road/on-farm.
Would it be possible to purchase a 2015-2019 ECM and then reprogram (or pay someone to reprogram) that ECM to run my 2020 truck exactly how my factory original one does?
A new 2020 ECM seems to be around $1k but I can find the 2015-2019 ECMs for a song, as they're used.
Am I thinking too simply, here?
I know there's several changes to the 2020 trucks and I'm guessing the ECM is also unique but figured it's worth a new thread query.
Thanks!
Old Dec 27, 2020 | 06:03 PM
bbronco66's Avatar
bbronco66
2020 trucks have two BCMs so the second module would not have a way to communicate to a previous year PCM.
Old Dec 27, 2020 | 06:09 PM
Ingotsilverf350
Makes sense, thank you!
I'll just wait for 2020+ compatible EZLynk "updates"
Thanks, again!
Old Jan 23, 2021 | 11:35 PM
Ingotsilverf350
If one were to order part number LC3Z-12A650-KANP (new Motorcraft ECM for 2020 6.7 PSD F-250), would it come pre-programmed from Ford or is this essentially a "blank" ECM that you'd need to get loaded/programmed after purchase?
It's pricey but might be worth it to retain the factory ECM and use this "spare" ECM for "testing" tunes when you go off-road.
Thoughts?
BBslider001
Sep 12, 2020 08:44 AM
JHForman812
Nov 23, 2019 11:36 AM
navistardiesel
Nov 29, 2016 06:09 PM
joneskl
Apr 5, 2016 11:56 PM
02biege44
Apr 5, 2003 11:56 PM
