v8 engine options
Old Dec 26, 2020 | 05:33 AM
Kirk-NJ's Avatar
Kirk-NJ
v8 engine options
Have a T-18 trans. Would like to know what V8 would direct bolt on to this trans. Thanks
Old Dec 26, 2020 | 06:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
depends on what you are putting it in. the T18 was used in a lot trucks for a lot years.
Old Dec 26, 2020 | 07:49 AM
Kirk-NJ's Avatar
Kirk-NJ
Trans and rear is in a tractor. Would say mid 60’s to early ‘70’s. It had a 4 cylinder 192 engine in it. Taking that out to use in a puller. Looking to replace with V8 with bellhousing that will bolt up. I was think mid ‘60’s to mid ‘70’s truck motor might work. Will need engine and bellhousing cause my bellhousing won’t wok
Old Dec 26, 2020 | 10:20 AM
tjc transport
i ain't rite
well if that is the case, anything is possible. .
from a 50's "Y" block all the way up to a 460
plus the "other guy" engines
Old Dec 26, 2020 | 05:40 PM
85e150's Avatar
85e150
T18s were intro'd in 1966 to replace the T98. As such, they have the Ford "butterfly" rectangular tranmission to bell pattern. They were OEM in Ford pickups from '66 to '86. So a Ford OEM bell for the SBF and FE can be found fairly easily.
First things first, what is the pattern on your transmission?
T18 info:
https://www.novak-adapt.com/knowledg...anual/t18-t19/
As far as selecting a V8, well, all V8s are not created equally.
More info about what you are trying to do will help.
Old Dec 27, 2020 | 05:29 AM
Kirk-NJ's Avatar
Kirk-NJ
Here is the trans side off the bellhousing I took off
Old Dec 27, 2020 | 05:37 AM
Kirk-NJ's Avatar
Kirk-NJ
Putting the V8 in this. Would like it to be carbureted so basically ford any engine from mid 50's the mid '70's will work if I find the right bellhousing to mate up to the trans. Is this correct?
Old Dec 27, 2020 | 07:23 PM
85e150's Avatar
85e150
Anything with that rectangle pattern and the same depth as the one you took off. Each engine series has it's own pattern, so 302-351W is one, FE is another. 351M/400, and 460 share the bell, but stick bells that will work with your trans are more of a question due to depth.
You need to take your tape measure with you when you shop.
Old Dec 30, 2020 | 04:40 AM
Kirk-NJ's Avatar
Kirk-NJ
Will this bellhousing bolt up to my T-18 trans. I know it's off a 223 in line six
Old Dec 30, 2020 | 06:34 AM
85e150's Avatar
85e150
It won't fit any V8s. And I'd bet the transmission to bell pattern is a square. Not going to work at all if that's the case.
Bulldogmac
1997 - 2003 F150
Oct 15, 2019 08:22 AM
3KIDDAD
Dec 17, 2006 08:56 AM
joes52f6
Sep 18, 2006 11:37 PM
corvairkeith64
May 11, 2004 01:07 PM
papaul
Feb 4, 2001 09:20 PM
