Camper backfeed power
Old Dec 24, 2020 | 04:06 PM
Hunter....'s Avatar
Hunter....
I have a slide in camper and while 7 way is hooked up and key on the power out of the truck is charging the battery in the camper which is great, so with that said once key is off will any damage happen with the camper battery power back feeding into the truck.
Old Dec 24, 2020 | 04:59 PM
06pghescape's Avatar
06pghescape
I would not think so , I have left my 2013 hooked up to my travel trailer over nite with no issues. You may get more answer here ; https://www.ford-trucks.com/forums/forum294/
Old Dec 24, 2020 | 05:39 PM
Hunter....'s Avatar
Hunter....
What I was thinking too. Once the relay goes off power coming back should not matter
Old Dec 24, 2020 | 05:43 PM
muhford's Avatar
muhford
Your camper should have an isolater that keeps the truck batteries disconnected when your key is off.
Old Dec 24, 2020 | 06:09 PM
Hunter....'s Avatar
Hunter....
Maybe at one time it did but now it does not. As said though once key is off no power comes out of truck so I'm thinking there's no way of drawing off truck anyways. My biggest concern was the battery power back feeding into the truck with key off burning up something
Old Dec 25, 2020 | 12:52 PM
meborder's Avatar
meborder
Historically, ford disabled the power to the battery feed switch when the vehicle is off
this is to keep you from draining the starting battery if you use power for extended periods of time in the camper.
other manufacturers don’t do this and the truck battery and camper battery are always connected when the plug is connected.
Either way is fine and no harm done with either method.
unless you kill both batteries. Then you better have a “plan b”
AMXDREAMER
Jul 21, 2020 07:26 PM
Boatdude60
Dec 21, 2017 10:50 PM
jimjoebob99
Apr 29, 2010 07:03 AM
cps
Mar 30, 2009 11:12 PM
Gotto
May 29, 2006 05:18 PM
