Camper Wiring
Old Mar 30, 2009 | 05:36 PM
cps's Avatar
cps
Camper Wiring
My truck has the 7 pin connector for a camper or whatever. Does anybody know how to check if the camper battery is getting charged by the truck when you are plugged into the truck. I have power going to my 7 pin connector and i checked to make sure it is wired correctly. The camper signals and everything else works but could i just put a meter on the camper battery when hooked up and see if it is charging at 14.5 volts?
Old Mar 30, 2009 | 05:45 PM
rbaker6336's Avatar
rbaker6336
That seems the way to do it
Old Mar 30, 2009 | 05:50 PM
maevans's Avatar
maevans
I would check at the truck plug with a meter.
Old Mar 30, 2009 | 06:14 PM
danskool's Avatar
danskool
Go Bills !
If i remember right i checked mine last year. I took off + battery cable in Camper. I turned the key on (to activate towing relays) in the truck. The 12v stuff worked in camper. I did this to make sure the truck would supply 12v to camper in case i killed the battery and it would be able to raise my landing gear.
Old Mar 30, 2009 | 11:12 PM
cps's Avatar
cps
I killed my camper battery on the weekend while camping and was still not able to raise the jacks with the truck running so i must have some other electrical issues.
littlewhistlerlumber
Aug 8, 2022 06:34 AM
fballguy
Jan 5, 2016 10:28 AM
kidoo
Jun 3, 2013 01:18 PM
sedwardson
6.7L Power Stroke Diesel
Jun 10, 2011 09:56 PM
07F150trucknut
Electrical Systems/Wiring
Jan 19, 2008 03:56 PM
