Put it all together
Old Dec 23, 2020 | 08:47 PM
1966F100SC's Avatar
1966F100SC
Put it all together
Well I have the engine and heads back from the machine shop, everything installed in the block, however I have an issue. I don’t know where tdc is at. I still have the heads off, all I have is the pistons and crank and rods assembled. I also have the lower timing gear on. I have the timing straight up to start.
now I don’t know if I have it at tdc on compression or on exhaust stroke. I don’t want to put the chain and cam gear on with the engine on the wrong stroke. Please help!
Old Dec 23, 2020 | 08:54 PM
john jamieson's Avatar
john jamieson
Aren't there indexing marks on the gears? Often times they are just a punch mark.
Old Dec 23, 2020 | 09:08 PM
AZSCAWPION's Avatar
AZSCAWPION
The compression stroke is determined by the phase of the cam. Until the chain is installed there really is only 1 tdc for the piston. It is neither compression or exhaust until the cam is linked via the chain. Gears should be positioned so that marks line up. Crank mark @ 12:00 and cam mark @ 6:00
Old Dec 23, 2020 | 09:31 PM
1966F100SC's Avatar
1966F100SC
Okay so I have the crank gear at 12 O’clock and the cam gear at 6 o’clock, with the chain on.
so thag should get me at the correct position to assemble the rest right? It’s my first time rebuilding a full size engine, learning a lot.
Old Dec 23, 2020 | 10:13 PM
AZSCAWPION's Avatar
AZSCAWPION
Yes. With #1 piston @TDC crank gear mark @ 12:00, cam gear mark @ 6:00, both marks aligned.
Old Dec 24, 2020 | 11:39 AM
6t6merc's Avatar
6t6merc
At TDC in firing position there is no valve lift on #1 - the camshaft lobes will be pointing down.
Eric
derbydad276
Jul 28, 2017 01:36 AM
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
gooldg
Apr 2, 2015 06:29 AM
idahoFORD350
51
Oct 11, 2013 01:09 AM
F500Mike
Mar 28, 2013 09:00 AM
