Old Dec 23, 2020 | 08:54 AM
Rick23's Avatar
Rick23
I have a 1979 Ford F900 Fire engine with 29,000 miles on it. I took it out the other day and 40mph was my top speed. Is there anyone e on here familiar with these motors?
Old Dec 23, 2020 | 08:57 AM
mwoj's Avatar
mwoj
You’ll probably have better luck in the big truck forum. If I were to guess that sounds about right. Big truck + low gears usually means low top speed.
Old Dec 23, 2020 | 09:11 AM
Rick23's Avatar
Rick23
I understand big truck low gears, I just find it hard to believe that a fire engine in an emergency could only drive 40mph to a fire. Thank you for the big truck recommendation.
Old Dec 23, 2020 | 09:52 AM
440 sixpack's Avatar
440 sixpack
Something is out of whack. no on hi way truck in this era had a top speed that low. if it has a 2 speed rear axle did you shift it up ?
Old Dec 23, 2020 | 10:22 AM
Rick23's Avatar
Rick23
It doesn't have 2 speed rear axle.
Old Dec 23, 2020 | 10:28 AM
meangreen92's Avatar
meangreen92
Did the truck come from a city? I could see a crowded city being OK for a truck with a top speed of 40 MPH.
Old Dec 23, 2020 | 10:41 AM
Rick23's Avatar
Rick23
Came from Clemens North Carolina, speed governor has been removed so I am told
Old Dec 23, 2020 | 10:48 AM
440 sixpack
What transmission does it have ? what's the max RPM you can get out of the engine ?
Old Dec 23, 2020 | 10:58 AM
Rick23's Avatar
Rick23
5 speed manual but not sure on the size, 4000 rpm
Old Dec 23, 2020 | 11:06 AM
440 sixpack
Rare for a 5 speed not to have a 2 speed rear. very rare., I'm not even sure you could buy it that way.
Have you looked on the rear axle to see if there is a shift mechanism ? if it doesn't I'd jack it up and check your gear ratio.
jondeuce
Dec 20, 2016 02:23 PM
redbeard_trucks
20
Jul 2, 2011 05:44 AM
moose94
May 10, 2005 11:06 AM
Ron_CNY
Sep 24, 2004 11:53 PM
