Typical FE???
Old Oct 24, 2003 | 04:43 PM
DeanBob's Avatar
DeanBob
Typical FE???
I have has two FE engines (360 & 390) and they both developed the same problem later in life.
The problem is a chronic ticking noise in the engine, I know there's lots of different causes for ticking but I'll try to explain. When the vechicle is started everything is fine; it starts up, runs fine, no noise. After about 10 minutes of operation the ticking starts. If your going down the road it may stop for awhile or it may keep it up until you reach your destination. If you wait awhile and start it up again it's fine, no noise no nothing, but after 10 minutes of operation it start ticking again.
I suspect I'm reaching the life-expectancy of my engine and should be thinking about a rebuild or a replacement. But for once, I would at least like to know what's the cause; lifter, valve, etc.
If anyone has some information on they typical gremlins or weak link of the FE engines are I would greatly appreciate it.
Old Oct 24, 2003 | 05:12 PM
DuckRyder's Avatar
DuckRyder
My 360 was doing this.
The rockers shafts and rockers were worn out.
Old Oct 24, 2003 | 07:49 PM
turbosek2's Avatar
turbosek2
I have also heard that ticking can be a result of an exhaust leak around the exhaust manifold/block gastkets.
Old Oct 24, 2003 | 09:29 PM
willowbilly3's Avatar
willowbilly3
My 300 did the intermittant valvetrain tick for over 50,000 miles until I rebuilt it. I have also seen fuel pumps do this if there is enough wear for the eccentric to slap the arm.
Old Oct 25, 2003 | 06:19 AM
Opiewan's Avatar
Opiewan
i just put on new exhaust manifolds on my 360, and the ticking noises have stopped. guess they were just leaks on mine anyway
Old Oct 25, 2003 | 05:21 PM
BigBlueFord's Avatar
BigBlueFord
taps are not "Taps" for your engine, a knock is!
LFDFF35
Mar 24, 2012 12:13 AM
10strokin
Modular V10 (6.8l)
15
Oct 27, 2005 08:11 PM
venom_99
May 30, 2004 05:46 AM
irishred
1978 - 1996 Big Bronco
Dec 30, 2002 04:09 PM
