after this darn hurricane went through down here, our temperature went from 88 on sunday to 45 this morning. big change, and once again, i have that ticking noise on startup. i posted awhile back about a ticking noise when i start the V10 up on cold mornings. it lasts maybe 2 minutes then goes away. lots of you told me it might be a sparkplug ready to fly. so i changed them and toqued correctly. but it sounds to me like the old pushrod engines that had lifter noise. this only happens in cold weather starts and goes away by itself. i thought i remembered awhile back someone with a thread on piston slap. anyone have any ideas? thanks, matt
Matt,
I have had that "slap" since new. I can only guess that it affects the engine like the old "wrist pin tap" on the FE engines - which was none to speak of.
Many folks here have it and, like myself, have gotten used to it...or at least realize that it doesn't hurt anything. It's hard to say when you can't listen to another person's engine, but mine is barely audible anyway, but I know its there. It goes away sometimes in 15 seconds and sometimes last as long as 2 minutes, depending on the temps.
thanks big orn, i didnt figure it could be too serious because oil pressure is great, and it only does it on cold mornings. barely audible also, youre right.
turn up the radio, other than that you don't have any options. If it makes any difference, I have 116K on my V10 and have always had piston slap in cold weather. Sometimes I wish it wouldn't start instantly, so I could spin the motor with the starter for a bit, to get oil pressure built up. But such is life.
I can hear it now...
Caller: Yes, I have a Ford Triton V10. What can I do to make it to where it won't crank. I don't want it to crank right away.
Tech: Excuse me?
Caller: It cranks too easy and I don't want it to. I want it to spin over for awhile.
Tech: I...don't...understand.
Caller: Oh, forget it!
My 05 always takes about a 2 second crank to start, hot or cold and other 3 valve owners say the same. I am used to it now but all my older Ford Gas V8s always started without you ever hearing the engine crank.
I wonder why the new 3Valve has to turn over that long?
On the other hand it starts up in high idle very smooth and very quiet,
hot or cold and even after sitting for 4 days.
mines the same way.probibly due to all the sensers that have to tell the pcm what to do.
since it always starts the same way , cranks the same amount of time hot or cold i leave it alone. now as i think about it so did all the newer vw's i worked on 2 or 3 second crank
Mine doe NOT take any extra time to flip and catch...but I always turn key to run and attach seat belt while she finishes Power On Self Test (POST) then I crank her up. She fires off first rev every time.
Does the fly-by-wire throttle still have an IAC on the side of the throttle body, or does the computer just crank open the butterfly? That might be the reason for the delay... Although it sounds like the manufacturers want some "pre-lube" - maybe that way, the piston slap isn't noticable ...
My '97 Cougar 4.6L ticks when it gets cold out, but randomly - it doesn't always do it - it also has the piston slap sometimes... the tick is related to it...
If I beat the snot out of the car for 15 minutes, running up the RPMs a lot, the tick goes away for months... so does the piston slap...
So basically, what you're telling us Art is that you force-feed the tick and slap some sorely-needed oil? Reckon why?
It works. The tick goes away if I beat on it enough - I kinda wonder if it's really a lazy lifter (hydraulic lash adjuster)
"Back in the day" we could rinse out an old noisy FE engine with diesel, let it drain good, then fill 'er up with 50 wt oil and some STP, then let the engine get up to norm temps and force-feed it some of that concoction with a good WOT for a few seconds. It would quiten it down for a few miles, but soon that wrist pin would speak its mind followed shortly by the lifters.
I was doing some research on engine replacements. Jasper uses graphite coated walls on their pistons in their v10 rebuilds. Perhaps this is to help remedy the piston slap problem or to make an engine with piston slap last as long as possilble. Or perhaps they use them on all their rebuilds as I didn't check out that idea... ?
Tony
