My boss just bought an 06 Explorer last week. He said he drove it this weekend and the heat wouldn't turn on unless it was adjusted in a certain spot. He said he could hear a clicking kind of behind the dash and then it would work. Is there a type of mix valve in there that would get stuck? It does have a code that has to do with the Body Control Module. I didn't know if the two were maybe related. Ideas? Thanks in advamce.
There is a blend vane actuator behind the glove box. Problem could be any combination of several things.
Take a look at these vids for tips on troubleshooting heat issues. https://www.youtube.com/results?sear...plorer+no+heat
They all do that at some point. Actuators are hard to get to. Gotta take the whole damned middle of the dash and the console out.
I managed to get it out just by taking the cover off that is by the drivers feet. Then the two bolts and two nuts on a small support behind it. With some determination the old one came out and the new one went in.
