Recommendations for a Replacement Battery
Old Dec 21, 2020 | 05:58 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Originally Posted by ford390gashog
The 5 year replacement is the best in the industry, not like you will need it. I have posted several times on these. I have installed hundreds of these in outlr fleet trucks and have a pair in my personal truck and they are over 8 years old and still test 80% and have been in 3 trucks.
I have these (even though I took some flak about not doing both at same time , I did get them both within two weeks !! ) I also use a battery tender to keep them up as my truck is not a daily driver . No issues and no corrosion .
Old Dec 21, 2020 | 06:50 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by GABAR
DieHard Platinum from Advance Auto Parts would be a good choice.
I used to run them when they were basically an Odyssey battery, I'm not sure about this recent reincarnation though.
Old Dec 21, 2020 | 07:57 PM
Tedster9's Avatar
Tedster9
Originally Posted by finnf250
Thanks guys for the X2 suggestion! Just placed an order online and will be picking the battery up later today. Fortunately I have a Batteries+ store not too far from where I live. The passenger side battery was bad, had only 9.6V and 7 CCA left, even though I had recharged it.
A good sized unit capable of supplying lots of Amps is needed to reliably charge dual setups. Keep 'em plussed up so they don't get mismatched and they should last a lot longer and give good service. 15 to 20 amps and let 'em cook.
Old Dec 21, 2020 | 08:03 PM
ocwill11's Avatar
ocwill11
I have had good luck with optima and duralast gold....
Old Dec 21, 2020 | 08:35 PM
ford390gashog's Avatar
ford390gashog
Ship sailed in 2013 for those. They were Odyssey batteries in a grey case. Now they are just a name on a Exide battery.
Old Dec 21, 2020 | 08:36 PM
ford390gashog
Make sure to get both batteries.
Old Dec 21, 2020 | 08:41 PM
4wd6.7L's Avatar
4wd6.7L
Is there any special procedure necessary after replacing the batteries, or is it just put em in and drive?
Old Dec 21, 2020 | 08:46 PM
dieseldrew's Avatar
dieseldrew
Die-hard batteries were manufactured by Exide then later by Clarios, now Advance Auto Parts.
Old Dec 21, 2020 | 08:52 PM
4wd6.7L's Avatar
4wd6.7L
Not the Platinum of the past. Unless Exide also manufactured Odyssey.
Old Dec 21, 2020 | 09:01 PM
ford390gashog
The DieHard brand is made by Clarios under contract with AAP who purchased the DieHard name in 2019 AAP is not a manufacturer. The old DieHard Platinum batteries from 2008-2013 were 100% Odyssey in a different color case and made by EnerSys.
Old Dec 21, 2020 | 09:07 PM
KU4OJ's Avatar
KU4OJ
If your budget is anything like mine the premium batteries from NAPA and Auto Zone have done well for me for 25 years or so. Never had a NAPA battery fail under warranty. Did have an Auto Zone die under warranty. Swapped it right out, no receipt, no questions and didn't even test it.
Old Dec 21, 2020 | 09:48 PM
finnf250's Avatar
finnf250
Good advice. Ordered another one, will pick it up tomorrow.
Old Dec 22, 2020 | 02:00 PM
  #28
minke's Avatar
minke
Write down your radio pre-sets.
Old Dec 22, 2020 | 02:32 PM
  #29
Ricktator's Avatar
Ricktator
I use walmarts agm battery. Has a good warranty and cheaper than most agm batteries.
Old Dec 22, 2020 | 06:23 PM
  #30
finnf250's Avatar
finnf250
Both X2Power batteries are now in, truck started right away. Didn't lose any radio settings, maybe because I did one battery at the time (?)
