Truck Weight
Old Dec 20, 2020 | 06:53 AM
Dan V's Avatar
Dan V
Truck Weight
So on my way to work this morning, yes I know it's Sunday, I rolled across the scale at the local scrap yard.
2001 F250 Crew Cab, SWB, PSD, 4x4, 4R100, Coils spring conversion, Move front bumper, On Board Air. 1/2 tank fuel and driver
7920lbs
I'll get the front/rear at a later date.
Old Dec 20, 2020 | 07:13 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
7920lbs
Each time we take construction debris to the landfill for recycling or disposal, we weigh in and out.
The weight has always been right about 8,000 lbs.
2000 F250 SuperCab, SWB, PSD, 4X4, ZF6, newish leaf springs with traction bars and air bags, Ranch Hand grille guard, 265/75R16 Cooper tires, fuel varies with an auxiliary tank in bed and 75 gallon total capacity.
Old Dec 20, 2020 | 07:23 AM
Shovelheadrob's Avatar
Shovelheadrob
Full tank of diesel, full freshwater tank & fully laden garage too. Weight is KG
Old Dec 20, 2020 | 07:54 AM
Sous's Avatar
Sous
FTE Emeritus
For those of us that refuse to change the way we count or measure things, the weight for Rob comes up to 21,561 lbs.
Old Dec 20, 2020 | 08:03 AM
Shovelheadrob
Thanks, we do things a little differently here in the UK, most things use metric measurements, except things like plywood boards, they're still 8ft by 4ft, we buy fuel in litres but measure it's use in mpg, all our road distances are in miles yet the road sign warning of for example a junction will be in metres, it's a f##ked up system for sure.
Old Dec 20, 2020 | 09:19 AM
bigb56's Avatar
bigb56
My CC 4X4 SRW LB with full tank and two passengers, fiberglass topper, 2 suitcases and a few road tools weighs in at 8860 LBS.
Old Dec 21, 2020 | 06:11 AM
JOHN2001's Avatar
JOHN2001
My 2001 in my profile picture. Ccsb 8" lift at the time I had 36x14.5s on 16x10 wheels empty with me in the truck was at 8020
Old Dec 21, 2020 | 06:20 AM
FordTruckNoob's Avatar
FordTruckNoob
I was about to ask if that trailer was filled with helium.
Old Dec 21, 2020 | 08:34 AM
Shovelheadrob
Haha, it's still a long way from being maxed out, but it's on the limit (actually over, but this weigh was for information purposes, I would normally not carry freshwater) for the 350 truck. The trailer maxes out at another 1400 kg or 3080lbs on the axles.
It tows just fine.
Old Dec 21, 2020 | 11:33 AM
JayTheCPA's Avatar
JayTheCPA
Last I checked, wheel diameter for tyre size is still in inches as well. The rest of Europe does not want to admit that either
And to stay on topic, I clock-in around 8,200#'s with just one person, some recovery gear in the cab (dumb suburban drivers get stuck in just 3" of snow), open bed (no cap), and full-ish tank for the SD. Have not had a chance to run the OBS over a set of scales yet.
Old Dec 21, 2020 | 11:46 AM
Shovelheadrob
Good point, although we/they did actually make some metric diameter wheels/tyres back in the 80's, talk about reinventing the wheel
https://www.ctyres.co.uk/general/metric
Old Dec 21, 2020 | 11:57 AM
empiretc's Avatar
empiretc
damn, last time we weighed old green, it was right at 8k. crew cab 2wd. fat driver in the seat.
Old Dec 21, 2020 | 10:48 PM
RA101725's Avatar
RA101725
Banned
My 2wd cab and chassis was down to around 6200 at one point with no driver and low on fuel. Had to get a Cat scale ticket for title and registration purposes in WA. After adding the hitches it is up to around 7500 with a full tank of fuel plus me and my tools and crap in it. Could shave around 150 lbs by switching to the aluminum wheels and lighter tires.
Old Dec 22, 2020 | 07:39 AM
udsuth78's Avatar
udsuth78
E99 xclb 4x4 Flatbed tooled out for the average day 10,200lbs. My girls got some booty.
Old Dec 23, 2020 | 09:34 AM
One Sock's Avatar
One Sock
4520 lbs front, 3180 lbs rear, measured at a closed DOT scale.
2000 F-350, 7.3, extended cab, SRW, 4R100, 4x4, 33" tires, heavy steel tool box in the back with full set of tools, tank about 3/4 full, camping gear/food/water in back seat, myself (skinny dude) in front seat.
