I am ALL for helping you, and hope you take this as just my .02. People will be able to do a better job helping you if you stick to a single thread. You have started 5 new threads about the same brake swap in about 5 days. Tough to bounce back and forth to figure out where you are in the swap now...
All in all, those radius arms are toast. The bushings slide on the rotted out part. So it will always turn funny if you use those.
I'm not 100% certain, but I believe you might be able to reuse your old radius arms.
You should be able to tell pretty easily by taking a few measurements.
getting a pair of 74 2wd radius arms from georgia, just checking, those should match the 77's?
thanks dave
All years of Bumpside and 1973 F100/250 4X2 without stabilizer bar were the same.
1974 was different but was replaced by the 1975/77 F100/150 (and various F250s) ones. I believe as of 1974, they were just changed to stamped steel.
So the short answer is...yes. They should work.
