Hi to all,
Have 2005 Excursion (AKA The Dobie Limo) it has done this on and off since I have owned it. start drive go to somewhere turn off no problem. Now here is what happens from time to time. Go to start and all the lights light up hit the starter and nothing. Sometimes let it sit for a bit starts right up. Had dealership reprogram the PATS worked fine and low and behold it doing it again. Of course it is acting up when it is 17 degrees out and not in the garage. Here is my Question after seeing a few things on youtube. Could it be the Fuel Pump Mod like they have on the F series were it corrodes up and breaks the circuit board causing to back feed power to the ECM. Does the Excursion have this part and where would it be located at? Also I just found out that if you hold the odometer reset an then turn on the ignition switch you have a self test and code reader with a whole lot of info but where do you find the info to decide what you are reading? This little feature works for all ford products from late 90s and up if it has digital odometer.
Thanks to all
Bob
Do you have a gas or diesel? Any codes? What is your batteries condition? New/old. 17 degrees is cold has heck. Then need to check voltage at starter and solenoid. Body grounds dirty. Do your lights go out when trying to crank it?
