4HI question
Old Dec 15, 2020 | 07:10 PM
willynilly's Avatar
willynilly
Originally Posted by _hedge_
Superduty has heavy duty old-school u-joints where the axle meets the front wheel. They change their speed and kind of bind up and release when turned sharp. It can get bad enough sometimes to cause a sort of hop. Lighter duty vehicles and front wheel drive have CV (Constant Velocity) joints in the same place which turn nicer but aren't as heavy duty.
https://www.youtube.com/watch?v=WH8WjJ_ljjY
well actually a cv is a long lasting joint, assuming theyre high qaulity and not chinese junk. its one main drawback is the boot that could be punctured or other wise damaged during offroad. with no boots to worry about, you could argue a ujoint is more rugged offroad but their torsion strength goes down hill fast when its turned off center while a cv maintains close to full strength i believe
Old Dec 15, 2020 | 08:21 PM
Desert Don's Avatar
Desert Don
Right on. RCV is as good as one can find; but still with a Super Duty 4WD system there is still going to be wheel hop and binding when in 4WD and high traction.
Old Dec 15, 2020 | 09:24 PM
willynilly's Avatar
willynilly
honestly i think you could use a smaller cv and be just as good as a bigger ujoint. the joint and shaft have to handle the worse case scenario which is tire at full lock and engine full power. for simplicity lets say the joint will see 1000lb torq at full power and steering lock. you need atleast a 1250lb rated ujoint (figuring a 25% loss of strength at full lock. cv however could be a smaller 1000lb rated because you wont have the 25% loss
Old Dec 16, 2020 | 02:26 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by MKrenn
Or unlock your hubs and drive in 4H! Kinda like peein in your pants - You get a good feeling but no one notices...... LOL
That only works on trucks with the manual t-case. ESOF trucks have auto hubs, and will engage when you select a 4wd option with the dial.
And either way, 4H with unlocked hubs is the same thing as 2wd...so what's the point?
Old Dec 16, 2020 | 09:05 AM
00t444e's Avatar
00t444e
The reason you get binding when turning in 4x4 is because the front and rear axles need to turn at a different speed but they can't since they are locked together by the transfer case. IFS trucks with CV joints will still bind up when turning in 4x4 on a hard surface.
Old Dec 16, 2020 | 09:43 AM
willynilly's Avatar
willynilly
with open differentials a cv joint system shouldnt bind much in 4x4 . ya the front and rear is connected via tcase but theres linear speed on both sides of the joint regardless of angle. the turned front wheels may travel a bit further or shorter than rear wheels but i dont think it causes much binding like u joints
ujoints. on either side of the ujoint , the shafts dont travel constant once its turned off center. i believe this is why u joints hop and bind. the travel on the stub shaft side is a eliptical speed rate as show in the video
and a ujoint strength goes down once its turned off center as well
Old Dec 16, 2020 | 10:17 AM
00t444e's Avatar
00t444e
https://youtu.be/LCMZz6YhbOQ
They will both bind even with open diffs in both axles, that's why you shouldn't use part time 4x4 on a hard surface. You can pull the rear driveshaft and drive around in front wheel drive even with U joints on the front axle and not have any binding, I have had to do that several times.
Old Dec 16, 2020 | 10:54 AM
willynilly's Avatar
willynilly
i dont know what we are arguing about here. binding aside, the guy who said cv joints are for lighter duty vehicles is completely wrong. a lighter rated cv could be used in place of a heavier duty ujoint
Old Dec 16, 2020 | 11:43 AM
00t444e's Avatar
00t444e
I know in the Jeep world that isn't the case at all, many Grand Cherokees came with CV joints in the Dana 30 front and swapping them out for U-joint axles is a common upgrade becuase they are way stronger, RCVs are the only CV joints that come close in strength and last time I checked they are over $1000 a pair for a Dana 30, I bet they cost double that for a Dana 60.
Old Dec 16, 2020 | 01:19 PM
willynilly's Avatar
willynilly
dude i dont care what the jeep cherokee world does. i dont care what your opinion is. the moment a ujoint turns off center its strength goes down hill. at 90* its lost 50% . at 45* im sure its lost 25%. i already explained in black and white why a lower rated cv could be used in place of a higher rated ujoint. its very likely the jeeps dont want a common cv because the concearn of boot damage on the trail, which i mentioned already in the beginning. size for size the cv is a stronger joint.
Old Dec 16, 2020 | 01:28 PM
00t444e's Avatar
00t444e
They replace the factory CVs because they explode when you put larger tires and/or a locker in the front axle, U joints have proven to be far stronger and that is a fact. And when is an axle U joint ever turned 90*? Even half of that is pushing it.
Old Dec 16, 2020 | 02:00 PM
willynilly's Avatar
willynilly
well of course large tires make thing explode. hubs , axle shafts, transmissions , ring gears , tcase etc etc
what theyre doing is replacing a cv that wasnt meant for large tires, in favor of a ujoint thats probly 2x or 3x larger, to offset its strength loss at angle. atleast you should provide the entire story and not leave any details out
your a ujoint fan boi im sure. i like ujoints as well but i know theyre not a better joint. except to say that you never have any risk of blowing a boot 100miles from nowhere
Old Dec 16, 2020 | 02:13 PM
  #28
00t444e's Avatar
00t444e
Nope they replace CV joints that came factory in those axles with factory U joint axles and U joints, you can get them cheap out of a junkyard. There is upgraded chromoly axles and U joints available, but even the factory size U joint axles are far stronger than the CVs.
Old Dec 16, 2020 | 02:16 PM
  #29
MKrenn's Avatar
MKrenn
Well, I had a 1975 Dodge W150 4x4 that had a factory CV joint on the T-case end of the front driveshaft...... Hmmmmmmmm
Old Dec 16, 2020 | 04:56 PM
  #30
jimzpsd's Avatar
jimzpsd
Could the Jeep guys prefer a u-joint over the cv because its easier or cheaper to replace while on the trail?
