First hookup
Old Dec 13, 2020 | 11:05 AM
jayro88's Avatar
jayro88
Originally Posted by meborder
don’t worry about getting the tow vehicle level. Worry more about getting the front wheel well at the same height with the bars hooked up as they are unloaded. Getting the same height loaded as unloaded is your best way of knowing that the hitch is returning all the weight to the front axle.
how level the TV sits is more a function of spring rate on the rear axle and any additional cargo weight you carry in the back. Those excursions are a fair bit softer in the rear than an equivalent F250 so having more squat in the rear is to be expected.
Okay. In the past I had always tried to get the drop in the front wheel well and the rear wheel well to be as close to even as possible....and have the trailer level or slightly leaning towards the tongue
Old Dec 13, 2020 | 12:25 PM
SpencerPJ's Avatar
SpencerPJ
Based on your last 2 posts, I think you are as good as can be. My tongue weight varies a lot, depending if I have a couple totes of firewood in the TT or not. Keep driving it and see. That is a decent size trailer, not like they are aero dynamic, lol.
Old Dec 13, 2020 | 03:12 PM
Kellem's Avatar
Kellem
From the pic, looks pretty good but watch the nose, slightly down is acceptable.
Like to add,
I've had the same Reese DC on last 4 trailers and always kept things simple.
Went by 12 - 15% of trailers GVWR to determine what trunnion bars were required " got a bunch of them " but another consideration reared it's head.
On latest trailer ( 2020 Outback) wife and I now carry 60 gallons of fresh water on every trip regardless of hookups.
Because the the tank is located ahead of axles it increased tounge weight which required 1200# trunnion bars and a readjustment.
All the spring/trunnion bars that I'm aware of are rated to maximum tounge weight.....which I've found to be true.
Ted Jacobi
Dec 31, 2019 08:01 PM
Rudeman
Aug 20, 2019 08:17 AM
System
Feb 16, 2017 09:38 AM
Rovernut
All Things Towing
Jul 6, 2015 09:39 PM
ClintD1
Dec 31, 2012 06:33 AM
