Ignition
Old Dec 11, 2020 | 04:02 PM
runlegacyevents's Avatar
runlegacyevents
Trailering
Ignition
So the guy I bought my 66 F100 lost the key. So I need get a new ignition. I don’t know what to buy can some one help me?
Old Dec 11, 2020 | 04:11 PM
dubya TF's Avatar
dubya TF
You'll likely need to drill out the old tumblers to replace them. Normally you use the key and a paperclip to remove the tumbler. Not sure as I've never had this problem.
Just one of many options for replacement parts:
https://www.dennis-carpenter.com/tru...ical/ignition/
Old Dec 11, 2020 | 08:57 PM
F100 '64's Avatar
F100 '64
Pull one of your door lock cylinders out. They will have a number on them and if they and the ignition are original a good lock smith will be able to make a key for you. Otherwise you can buy a complete set for a reasonable price so you'll have all the locks use the same key.
Best of luck, Pat
Old Dec 12, 2020 | 06:40 AM
Tedster9's Avatar
Tedster9
A locksmith should be able to help? They didn't have that many tumbler combos. Find a key that works, that way can remove the lock from the actual switch with the paper clip trick and not tear everything up.
Old Dec 12, 2020 | 08:51 AM
runlegacyevents
Trailering
What’s the paper clip trick?
Old Dec 12, 2020 | 10:13 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Ignition switch removal - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Dec 12, 2020 | 09:35 PM
F100 '64's Avatar
F100 '64
You have to have the key and use a paper clip to remove the cylinder. No key, you're not removing it.
munireusa
Apr 27, 2017 08:26 AM
Tedster9
Jan 27, 2015 12:35 PM
F-6Flathead
Feb 4, 2009 11:14 PM
fordinmudd
Electrical Systems/Wiring
Jul 28, 2006 04:28 PM
lerry
Jul 6, 2001 11:11 AM
