2001 Expedition interior electronics are dead
Old Dec 11, 2020 | 09:47 AM
alloro's Avatar
alloro
Originally Posted by Tjeepdrv
No, 86 was dead.
Then check the brown/orange wire coming off the selector switch for power. If there isn't any power the switch is bad, if there is then there is a break in the wiring from the switch to the blower relay socket.
Old Dec 11, 2020 | 09:57 AM
Tjeepdrv's Avatar
Tjeepdrv
No power. I'll try to get to a salvage yard today or tomorrow. Thanks for all of your help so far!
Old Dec 12, 2020 | 12:12 PM
Tjeepdrv's Avatar
Tjeepdrv
Alright, I replaced the switch and now the truck is fully dead. Nothing happens when I turn the key. I noticed when the key is off, I can unplug the brake pressure switch and some relay starts clicking, but otherwise I can't tell there's even a battery in the vehicle.
Old Dec 13, 2020 | 09:54 AM
alloro's Avatar
alloro
So you changed the selector switch and the truck went completely dead? What happens if you swap the old switch back in? Did you check to see if you blew any fuses during the switch swap?
Old Dec 13, 2020 | 12:46 PM
Tjeepdrv's Avatar
Tjeepdrv
Alright, just for the heck of it, I threw a new starter solenoid at it and now it seems to reliably start again.
The old and new AC controls seem to do nothing. No fuses are blown.
Old Dec 16, 2020 | 03:47 PM
Tjeepdrv's Avatar
Tjeepdrv
After sitting on this for a few days, I looked at it again to see if I was missing something. The diagram above shows a white/violet wired going into the Function Selector Switch and a brown/orange coming out of it. Mine has 4 on it. From top to bottom, there's blue/purple, purple, white/purple, and orange/brown. Blue/purple is hot, and nothing else is. Is the third one down, white/purple, supposed to be hot? It appears to be the one coming from the central junction box and has no power. I don't see them on the diagram, so what are wires 1 and 2, blue/purple and purple?
Old Dec 16, 2020 | 04:18 PM
projectSHO89's Avatar
projectSHO89
The WH/VT wire should be HOT IN RUN via F22.
Old Dec 16, 2020 | 04:26 PM
Tjeepdrv's Avatar
Tjeepdrv
The fuse is good, so I guess there's a break in the wire between the fuse box and the switch then. Thanks!
oachs83
Dec 31, 2019 09:09 AM
expeditionph
Apr 24, 2013 11:34 AM
rb8484
Jan 22, 2013 10:17 PM
tdpower
Jan 28, 2012 01:32 PM
bigworm
Electrical Systems/Wiring
Aug 20, 2006 06:47 PM
