Regular cab rolling cart
Old Dec 6, 2020 | 11:07 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
Hello everyone!
It appears that my current project, Tug, a 1991 F150, needs to pull the cab off the frame ( frame damage). I have to do some minor patch work to the cab, a pair of cab corners and a rocker panel, has anyone made a cart that the cab would mount on, so that i could be able to do the bodywork, and maneuver it around my shop? I have a few ideas, but i would love to see anyone else's designs before i start building my cart next weekend.
Thanks!
Boot
Old Dec 7, 2020 | 09:37 AM
humphrey169's Avatar
humphrey169
I made a little trailer deal that leg on the back so I could roll the trailer tongue up and it'll set so you can work on the roof and floor. Make sense?
Old Dec 7, 2020 | 10:45 AM
Bootlegger's Deluxe
Originally Posted by humphrey169
I made a little trailer deal that leg on the back so I could roll the trailer tongue up and it'll set so you can work on the ro2of and floor. Make sense?
Got A pic?
Old Dec 7, 2020 | 08:09 PM
mzwizanski's Avatar
mzwizanski
I just used some of the cheap dollies(with the carpet on them) from harbor freight. Had them under the rockers then rolled it onto the back to work on the floor.
Old Dec 8, 2020 | 01:13 PM
JPIECHOC50's Avatar
JPIECHOC50
I just measured the distance between the cab mounts and made a rectangle that big, I used 2x8's for the lumber.. so its 2 rectangles with about 2 foot legs in between. for the legs i screwed the 2 pieces of 2x8 in and "L" shape and its plenty sturdy. the rear cab mounts are higher so i just shimmed them with 2x4 pieces. if you're using a cherry picker like I did make sure to leave clearance on the bottom the get the cherry picker underneath (I learned that the hard way) and 4 swiveling caster on bottom and it work great.
Old Dec 8, 2020 | 04:32 PM
Diesel_Brad's Avatar
Diesel_Brad
I made one. very versatile.
all measurements approx since it is not here curently
2" thin wall square tubing welded into a 4'x5' rectangle.
(4)8" swivel casters(had small casters, they sucked, took them off)
I made legs that go up from the rectangle frame. They are PINNED onto he rectangular frame so they are removable
The front has 2 legs that go up about 6-8" and have a rail across the top to let front cab mounts rest on it
The rear has 2 legs that come up about 12-14" and have a rail across the top to le the rear cab mounts rest on it
This same cart I have a pair of tall legs (about 3' tall) for a bed to set on.
I have used this cart for a 79 ford, superduty and ranger supercab. also about 8 different beds
The cart
From the rear
With the bed on it
Old Dec 8, 2020 | 10:11 PM
Bootlegger's Deluxe
Thank you all for the input. i have a design drawn up, i think it will end up similar to Diesel Brad's setup. I especially like the idea of a taller set of legs that allow for a bed to go on as well.
irhunter
Paint & Bodywork
Oct 1, 2025 01:00 PM
flattop460
Projects
Jan 17, 2011 11:09 PM
rods4life
Oct 10, 2008 07:56 AM
72F103
May 4, 2004 06:17 PM
noyozoid
Feb 15, 2004 12:06 AM
