Thoughts on this mod?
Old Dec 29, 2020 | 09:06 AM
  #31
Lmhayes88's Avatar
Lmhayes88
Originally Posted by Crotchety Ford truck only
ATC inline fuse holder wire looks 16 and others look 14
Does it matter what gauge I use? Will 14 or 16 work?
Old Dec 29, 2020 | 02:13 PM
  #32
Rjacks258's Avatar
Rjacks258
Originally Posted by ATC Crazy
And you couldn't be more wrong. Not all of us bought these trucks for weekly grocery runs and mall crawling.
95% do. Look at me and my big bad diesel that I will lift and put 24” wheels on it with super low profile tires and 100mm of negative offset, and a big exhaust tip so you know I am cool.
But hey, can ya blame Ford? And the aftermarket? it’s all a money game and they know Joe Schmoe will finance this $90k truck at $1700/mo cuz dIeSeLs ArE cOoL.
oh yea, I got a gas truck, for work.
Old Dec 29, 2020 | 02:16 PM
  #33
Rjacks258's Avatar
Rjacks258
[QUOTE=Crotchety Ford truck only;19617638]
This mod is the only way to actually turn off traction control for many trucks unfortunately. I did every combination possible with my T/C button on the dash, but T/C would always kick on if I was spinning.[/QUOTE
No guns, electric micro cars with speed governors, no rude people, no injuries, no one speaks against anything, government provides us equally with what we need, what a lovely world it will be then huh.............Stallone played in a movie like that with Wesley Snipes.
This dude gets it.
Old Dec 29, 2020 | 02:23 PM
  #34
wylecoyote's Avatar
wylecoyote
Has anyone disabled advance trac in forscan ? Does doing this in forscan do the same as pulling the fuse ?
Old Dec 29, 2020 | 06:18 PM
  #35
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I tried it on mine. The only thing it did was disable the button on the dash.
Old Dec 29, 2020 | 06:31 PM
  #36
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If you have to buy wire, go ahead and get 14ga. If you have 16ga laying around, it will work for such a short run.
Old Dec 30, 2020 | 05:45 AM
  #37
Klutch5000's Avatar
Klutch5000
Just a couple pics for the heck of it:
If your using an upfitter switch, just curious why you used a relay?
Old Dec 30, 2020 | 08:21 AM
  #38
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
With the upfitter switch OFF, the relay applies power to the ABS circuit from its 'normally closed' position (black wire going into the fuse box). When I flip my upfitter switch ON, it actually powers the relay to flip the power away from the ABS circuit and to a wire that goes nowhere (the yellow wire).
If you didn't use a relay, you'd have to keep your upfitter ON the entire time you wanted the ABS circuit to function normally (90% of my driving)
Old Dec 30, 2020 | 09:32 AM
  #39
Dienivek's Avatar
Dienivek
@ATC Crazy What type of relay did you use? [Normally closed relay?] (post alink?) Way better setup than from the video. (Nice job)
Old Dec 30, 2020 | 10:49 AM
  #40
Klutch5000's Avatar
Klutch5000
Ah makes sense, good idea. Do you have to clear the wrench from display when you turn abs back on?
Old Dec 30, 2020 | 12:07 PM
  #41
Crotchety Ford truck only's Avatar
The smart way
Old Dec 30, 2020 | 12:15 PM
  #42
What size wire did you use? Looks pretty clean with the black coating on it. Thinking of doing this to my truck just for dirt use.
That's not a coating it's shrink tube it gets cut longer than the crimp or solder connecter and slipped over the wire before connecting, make crimp or solder then slide tube over connection and apply heat it will shrink tight if you use the right size.
Old Dec 30, 2020 | 05:39 PM
  #43
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
It clears itself with every key cycle...just like nothing ever happened.
Old Dec 30, 2020 | 05:41 PM
  #44
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Amazon Amazon
Old Dec 30, 2020 | 06:35 PM
  #45
I did this mod to my truck a while ago. It works great.
And no, it's not for burnouts...it's for when I want or need full control of my truck because the stupid nannies won't let me do what I need to do, or will get me into more trouble...
When this mod is engaged, you will lose rear parking sensors, cruise control, factory navigation, and of course, ABS.
Makes rocking a truck to get it unstuck possible like 20 yrs ago
