226 engine
Old Dec 5, 2020 | 02:14 PM
blsd49's Avatar
blsd49
226 engine
On spokane craigslist: Don't know anything about it.
Ford 226 6 cyl flathead - auto parts - by owner - vehicle automotive... (craigslist.org)
Old Dec 5, 2020 | 03:49 PM
Brian1950F4's Avatar
Brian1950F4
That looks like it has some good, hard to find parts on it. Too bad it isn't closer.
Old Dec 5, 2020 | 07:32 PM
bobj49f2's Avatar
bobj49f2
Looks like a good deal to me. Would be nice if it's still in the truck to hear run. Yeah, if it was closer I'd have an extra engine in my shop.
Old Dec 6, 2020 | 02:36 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
That engine looks to be taken care of and not messed with. Bet it will run just fine, those engines are very rugged.
Old Dec 6, 2020 | 02:57 PM
bobj49f2's Avatar
bobj49f2
I personally favor the six over the eight. The worn out six in my F-2 is still going strong, I don't know if an flat eight would have gone through what I've put my six through.
I can't really tell if it's in a car or truck. The carb isn't a stock truck carb.
Old Dec 6, 2020 | 03:17 PM
Brian1950F4
Might be in a car? Battery tray would be on the other side in a truck.
Old Dec 6, 2020 | 03:55 PM
bobj49f2's Avatar
bobj49f2
Yes, you are correct. Closer look at the front body mounts aren't truck either. Same engine in the car as the truck I would assume.
Old Dec 6, 2020 | 04:00 PM
bobj49f2's Avatar
bobj49f2
Seems too far for most of us that would like to get it. It always seems like that. Right now I'm trying to work out arrangements to have a bunch of parts for my '37 Buick shipped from CA to me. I think it's a smoking deal even with the shipping. Anyone really needing this engine needs to check with the places that specialize in shipping engines or even Fastenal. I shipped a set of F-2 running boards via Fastenal. They were a lot cheaper than any other place. UPS and FedEx go nuts on prices for oversized items.
Old Dec 6, 2020 | 06:23 PM
blsd49's Avatar
blsd49
Yes it does look like it’s probably out of a car but most of the parts are the same. It’s about 90 miles for me and I’m considering picking it up just for the fact that a lot of the parts are so hard to find. I’ve owned a F1 with a 226 for 45 years plus and even the thermostat housing is getting almost impossible to find. Brian
Old Dec 6, 2020 | 06:35 PM
52 Merc's Avatar
52 Merc
It looks like the engine is in a truck to me. 49-51 Ford cars have a totally different frame and front suspension. I see truck steering box, truck tie rod and axle, truck motor mounts, truck inner fenders and left side upper shock mount. It has the wide fan belt, and firewall mount battery, albeit on the wrong side for a 6 cylinder. Cars have the battery at the left front and a big blower box where the battery tray is there. My 2c.
Old Dec 6, 2020 | 08:39 PM
51fred's Avatar
51fred
I agree, it looks like it is in a truck. Could be like mine where it was originally an 8 and was switched to the 6 sometime later. The battery tray was still on the passenger side. I moved it once I restored it.
Old Dec 6, 2020 | 08:53 PM
38 coupe's Avatar
38 coupe
It is in a truck. The steering box and frame parts for the motor mounts are truck only. 48 and earlier passenger car engine compartments look different and have the steering boxes mounted for cross steering.
Old Dec 6, 2020 | 10:11 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Only 90 miles away seems like a no brainer. You will be kicking yourself later if you don't grab it.
Old Dec 7, 2020 | 05:48 AM
Marauder2004's Avatar
Marauder2004
It also has the correct truck exhaust manifold.
Old Dec 7, 2020 | 01:43 PM
Brian1950F4
I have used engine shipping. Com before. Price was reasonable except they seemed to have dropped it. They did replace the distributor they crushed.
