I have a 1989 C6 with 50,000 pampered miles. The fluid was changed every year or 10k whichever came first. It uses Dexron-III/Mercon ATF, and will get a 28,000 GVW Cooler (or 47,000 GVW depending on which is better). I plan on converting to Pennzoil Mercon-V, which is partially synthetic. Will this cause any problems (leaking past the seals, etc)?
I also have a 1981 AOD with 90,000 pampered miles, 10k/annual fluid changes, and it's using Dexron-III/Mercon. I want to use Mercon-V, and it already has a 32,000 GVW cooler on it. Will I experience any shifting/leaking problems?
-Charlie
1981 Ford Thunderbird "GT", 5.0L, AOD, 2-bbl (soon to be 347 stroker w/ 400 rwhp)
1989 Ford E-150 Cargo Hauler, 4.9L I6, C6
2000 Ford Crown Victoria PI, 4.6L SOHC V8, 4R70W, 3.55s, Dual Exhaust, Go Rhino Push Guard, Steel rims with Type 170 center caps, Dunlop SP5000 Sport Ultra High Performance All-Season Tires
I think adding the cooler will do more than switching to a synthetic . Since you change the fluid & filter often that should suffice . I could see going to a synthetic if you towed & hauled a lot . Heat is the biggest problem for any auto trans , If you have a cooler that in my opinion is the best thing you can do for an auto trans .
Oh I know, right now it has a 19,000 GVW cooler and it's not doing the job. The van weighs 4200+ lb. and I figure it needs the largest cooler on the market: 28,000 GVW B&M racing cooler.
But I know Mercon-V is a partial synthetic, so it should hold up better. So you don't think I'll run into any shifting/leaking problems using Mercon-V in those high mileage trannies?
-Charlie
I plan on dropping the pan, changing the filter, draining the converter, and flushing out the cooler. The new fluid will be Pennzoil mercon-V, a partial synthetic mixture approved for use in Ford's modern automatic transmissions (Pennzoil states that it's compatible with systems designed to use Mercon).
Thanks and Happy Thanksgiving!
-Charlie
