Audio / Sync
Old Dec 3, 2020 | 03:32 PM
Jefff H's Avatar
Jefff H
Audio / Sync
I was in a wreck and when I picked up my truck the audio and sync were not working. I played around with it and got it to come on but at least every week the radio and Sync freeze up. Sometimes it comes back on it's own after a couple days and sometimes it comes on only after playing with the buttons in random combinations. Every time I go to take it back it starts working. Any Ideas? I don't want it sitting at the body shop for a month while they try to figure it out. I'm thinking it would be easier and cheaper to replace it. Is that possible? It's the Sync 3.
Old Dec 3, 2020 | 04:24 PM
ford390gashog's Avatar
ford390gashog
Failed APIM module get it replaced. Probably has nothing to do with the accident.
Old Dec 3, 2020 | 04:50 PM
Jefff H's Avatar
Jefff H
Do you know where this is located? Hard to replace? Expensive?
Old Dec 3, 2020 | 05:16 PM
2004Limited's Avatar
2004Limited
check this out?
Old Dec 3, 2020 | 06:21 PM
GABAR's Avatar
GABAR
Depending on the Ford dealer, plan on spending between $600.00-$1K to replace and reprogram it.
It’s attached to the back of the center stack display screen.
Very easy to replace but the APIM has to be programmed for your VIN#.
Some places online have APIM’s for sell and they can program it to your VIN#, ship it to you so you can install it for a little cheaper than a Ford dealer but in my opinion, it’s not worth the risk.
Before I had mine replaced, when I was using Apple CarPlay, everything worked well on the touchscreen but when I tried to use the SYNC 3 system, that’s when the problems would start.
I’m not sure if this would work for Android Auto but you might want to try it before going to the trouble and expense of replacing the APIM.
Good luck.
Old Dec 3, 2020 | 09:50 PM
Jefff H's Avatar
Jefff H
Thanks everyone, you've been very helpful. In the accident a stick poked up through the floor under the drivers seat where there is some wiring. Could there be anything related to the audio under the seat? Also the hill descent and the Advance Track service lights come on sporadically. Again only after the accident.
Old Dec 4, 2020 | 11:44 AM
GABAR's Avatar
GABAR
That stick must have hit the body plug and and entered the vehicle because I don’t see a stick penetrating the actual floor board.
With that being said, the actual wiring for some parts of the vehicle is under the actual sill plate and this wiring is part of the harness.
Any wiring under the actual seat and in my opinion is for the seat itself not for the audio system.
With that being said, you have other issues going on with the Hill Decent and Advance Track lights coming on.
Take it to a place like Auto Zone and let them scan it for free or, if you have a scanner, do it yourself.
I take it you didn’t get your insurance company involved with the repair right?
hobbie1
Feb 20, 2019 09:30 AM
tap1946
May 9, 2011 08:29 PM
mrad
Jun 10, 2009 06:47 AM
Greywolf
Tennessee Chapter
24
Aug 8, 2006 08:28 PM
Cardude_mad
Mar 23, 2002 12:18 PM
