disc brakes
Nov 30, 2020 | 04:17 PM
disc brakes
wanna convert to disc brakes on my f100 68 ranger, any kits out there you would recommend?
thanks dave
Nov 30, 2020 | 05:04 PM
Nov 30, 2020 | 05:15 PM
great info, thanks, i will be looking to grab disc brakes parts from 73+ ford f100's
awesome info thank you
Nov 30, 2020 | 07:53 PM
If you find one don't forget all the parts on the list.
Dec 4, 2020 | 12:20 PM
FYI/PSA/ICYDK
Front brake rotors for F100 and F150 2wd are the same all the way up until 1992.
Dec 4, 2020 | 12:27 PM
really??? easy bolt on? what else do i need to grab from the donor truck besides rotor and calipers?
thanks dave
Dec 4, 2020 | 12:29 PM
Quote:
thanks dave
The I beams and prop valve. Master cylinder and booster
Or you can have manual disc brakes like I do. I like the feel of the non-boosted brakes
Dec 4, 2020 | 03:11 PM
Front brake hose to frame brackets, drag links. Best to just pull the I- Beams with everything attached. If there is a sway bar get all those parts too.
Dec 4, 2020 | 04:22 PM
Quote:
The hose brackets were the same on mine.
Kingcw1966
Dec 18, 2020 04:48 PM
Tomget
Oct 2, 2020 02:16 PM
BushyTea
Jul 26, 2007 08:38 AM
67jc
Oct 28, 2003 09:10 AM
