Leaking Diff cover after Kelderman dual stabilizer
Old Sep 20, 2021 | 11:57 AM
  #31
willynilly's Avatar
willynilly
Originally Posted by mcmurm
I agree - , but this clearance issue really seems like a rookie mistake.
i wonder if thats why some folks have refered to it as the klunkerman ?
Old Sep 20, 2021 | 03:21 PM
  #32
Norcalpr's Avatar
Norcalpr
I don't think this is true. I didn't pull my diff cover off to look, but I called Kelderman and spoke with Kyle. He explained that when the diff cover is sealed from the factory the amount of sealant used is inconsistent. Sometimes there's enough that when the bolts are removed oil won't drain into the tapped hole. Other times there isn't enough sealant so oil does drain once the bolt is removed. This lines up with my experience when fixing the problem. After removing the bolts to apply Permatex, fresh oil was clearly draining from inside the tapped hole. It was fresh, clean, clear, gear oil. You could smell it without even putting it to your nose.
This tells me that the holes are tapped through and exposed to the oil.
I've literally regeared the front housing. The bolt holes do not go all the way thru. The casting is about an inch thick. They just thread into it...
Old Sep 20, 2021 | 03:24 PM
  #33
Norcalpr's Avatar
Norcalpr
Originally Posted by Lamoon78
Dual doesn’t mean something is going on
If you're putting a dual stabilizer to stop death wobble, or bump steer, you've got other issues going on...
Again, only one is needed. If you're alignment is correct and everything is nice and tight you don't even really need one for the street. its just because people lifted their trucks, thought 2 looked cool, and now everyone believes they need a dual stabilizer on a stock truck.
If a dual stabilizer is needed, why not 3? 4? 20?
Old Sep 20, 2021 | 04:10 PM
  #34
mcmurm's Avatar
mcmurm
Then there's no good in adding Permatex to the bolts and re-fastening. Both times I fastened the bolts I torqued them to 35 ft. lbs, which I believe is recommended, so I don't think the leak is caused by a lack of clamping force.
The other plausible explanation is what you said previously - force against the bracket is breaking the seal. Correct me if I'm wrong, but if this is the case, the only solution is to remove the product? Or find a gasket with more sealing tolerance? Or perhaps an aftermarket differential cover that doesn't flex under load of the stabilizer forces?
Old Sep 20, 2021 | 07:37 PM
  #35
Norcalpr's Avatar
Norcalpr
Yep, it might work for some because the head gets coated in rtv, but it could loosen up with that bracket pushing in it and make it leak again.
It could even be because the bracket is held off of the cover slightly (because of tolerance differences between each axle housing) so when you're tightening down on the bolt you're really just tightening on the bracket, and not on the cover...
You could do a beefy diff cover and weld a bracket off of that, but I still go back to why...
Read up here on posts about caster, get it to 5 degrees or so, set your toe, and run just one good stabilizer like a fox or bilstien in the factory location. It's all you need. Shoot I'm still running the stock stabilizer at 43k miles and after aligning the truck myself it drives just like a normal vehicle...
savagebagz
Sep 21, 2016 09:25 AM
TexasA&M
May 8, 2012 11:00 AM
X_Hemi_Guy
Nov 12, 2008 06:20 AM
drbalazo
May 24, 2007 11:54 PM
n9lhm
Nov 23, 2006 09:30 AM
