AFE or Sinister
Old Nov 29, 2020 | 10:56 AM
F350towing's Avatar
F350towing
AFE or Sinister
Looking at intake Y and CAC pipes.
Black Friday deals are great right now.
Are the y and CAC pipes worth it on a stock setup.
Old Nov 29, 2020 | 12:12 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by F350towing
Are the Y and CAC pipes worth it on a stock setup?
On a stock set up? No.
Judging by the product names alone, the AFE sounds a bit "iaffy." And the Sinister sounds, well, just like it sounds... sinister.
I wouldn't want anything iffy or sinister on my stock set up.
In all seriousness however, recognize that the stock Y pipe being connected to the compressor outlet horn offers a mechanical securement advantage that has to be compensated for with a metal strap bolted to the engine valley when these elements are segregated.
Old Nov 29, 2020 | 05:05 PM
Dan V's Avatar
Dan V
Your money is better spent on something like a Ford AIS.
Old Nov 29, 2020 | 05:19 PM
F350towing's Avatar
F350towing
I got kinda frustrated after spending too much time giving history on mods and then It timed me out on the post. So I just did a quick whaddya think...
WW2, AIH delete, 6637, Hydra with SDK tunes, RR plenum inserts, ummm... possibly preparing for KC stage 1 or just balanced assembly. No T4 in my future although I do like what I am reading about the lower spool on the 363.
Old Nov 29, 2020 | 06:32 PM
Dan V's Avatar
Dan V
That's the wish list, or, what you have done?
Old Nov 29, 2020 | 07:32 PM
RacinJasonWV's Avatar
RacinJasonWV
I'm enjoying the 363/small turbine, but I'm also not sure if the money spent on my small turbo setup can be "justified" compared to a KC drop in.
Skip the new Y and such in my opinion. I mean shoot, my T4 kit re-used the cold side IC pipe.
If it were me, I would spend my coin on the KC turbine/Riffraff wheel combo (Wes444 describes his good performance with this setup) or call KC to see if a Stage 1 would be suited for your needs.
Old Nov 29, 2020 | 07:52 PM
F350towing's Avatar
F350towing
That so far to date. PMS is kicking in again.
Old Nov 30, 2020 | 06:01 AM
sjbj's Avatar
sjbj
Two other options on the Y's that I've been looking at, but haven't pulled the trigger. A lot more affordable than the two you mentioned, but then again I don't know the quality...
https://ktperformance.net/i-23918025...-polished.html
https://www.ebay.com/itm/99-5-03-For...e/333785739190
Old Dec 3, 2020 | 08:32 AM
F350towing's Avatar
F350towing
I'm enjoying the 363/small turbine.
If it were me, I would spend my coin on the KC turbine/Riffraff wheel combo.
Ive read your posts on the 363 as well as eswift’s and seems like the way to go for the lower rpm spool.
Decided to save the $$$ for needs vs wants. Will they help make more power... maybe, will they look good... sure, are they needed, not one bit.
For now I will just enjoy what I’ve done to date.
mat-it
35
Oct 7, 2020 04:12 AM
JAE88
6.2L V8
Jan 13, 2014 06:48 PM
cuda66
6.4L Power Stroke Diesel
Sep 17, 2013 01:59 PM
Liquid10Rider
Apr 20, 2012 06:19 AM
