Driver's door handle
Old Nov 29, 2020 | 09:48 AM
Speedwagon98's Avatar
Speedwagon98
2002 Ranger supercab. The driver's door handle doesn't always want to open the door, kind of. When I pull it up all the way, the door doesn't always open. I figured out the other day that if I push in on the door at the same time, it will open.
At first, I figured it was a typical Ford stretched cable issue, but there isn't a cable there. After looking at it, I wasn't sure how to correct the problem. It feels like it needs to engage sooner to open the door correctly. Any ideas on how to fix it? Or do I just need to replace the mechanism?
Old Dec 1, 2020 | 10:07 AM
xamack24's Avatar
xamack24
Have you tried lubrication the latch and post it attaches to? That would be my first move. Also make sure there is no weather strip or something else keeping the door from closing tightly. I had a seatbelt that didn't retract all the way and got wedged in the door, causing the problem you describe. Otherwise, you may have to take the interior door panel off and look at the mechanism. I don't know what's in there, but there might be something to adjust or lubricate in there.
Old Dec 2, 2020 | 01:34 PM
Speedwagon98
I actually did pull the panel off, and inspect inside the door. This is how I knew it was not cable driven. Everything seemed to move fine, and I saw no adjustments I could make.
Old Dec 2, 2020 | 07:07 PM
mfp4073's Avatar
mfp4073
on my 04, the passenger side door handle where it mounts to the body, is getting a little loose. Could it be something similar?
Old Dec 3, 2020 | 04:48 PM
Speedwagon98
Just opened it up again to check. Door handle is not loose.
Examined the inside of the door thoroughly, and took a few pictures. But after not seeing anything what I could adjust, or anything loose, or not functioning correctly, I moved to lubricate the latch mechanism from the outside of the door. This is when I noticed there is a small wear mark on the lower side of the latch mechanism, from where it is contacting the latch pin on the rear door. So I made a slightly adjustment to the pin, and I'll see if that's the problem.
It seemed, upon a few opening/closing just now, that it is easier to open. Time will tell.
Old Dec 3, 2020 | 04:52 PM
xamack24's Avatar
xamack24
Hope that fixes it for you. Sometimes it's just little adjustments like that, that can fix it.
Old Dec 7, 2020 | 12:28 PM
Speedwagon98
This seems to be fixed. Adjusting the latch pin appears to have fixed the issue.
Old Dec 16, 2020 | 11:49 AM
littlecobra1977's Avatar
littlecobra1977
Some of these rods, have a slight bend to them, I know on my 78 fords, they could get stretched or straightened out a tiny bit. If you removed the rod and rebent it, it would work like a charm. Don't know if this will help you.
Old Dec 17, 2020 | 07:51 AM
Speedwagon98
Um, I stated that I had fixed the problem. So there's no need to do anything else.
Old Dec 20, 2020 | 09:29 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The pin doesn’t usually get out of adjustment. I’m curious if the hinges are worn causing the door to sag making it harder to open.
GavinL
Nov 21, 2018 12:51 PM
Mocha Joe
May 29, 2013 05:34 AM
krzldy1949
1997 - 2003 F150
Mar 9, 2013 12:39 PM
Jacksfirstdiesel
20
May 19, 2010 12:01 AM
2 stroke man
17
Jan 15, 2009 10:59 PM
