Adjusting Door Hinges
Old Nov 27, 2020 | 09:01 PM
Para_Bellum's Avatar
Para_Bellum
Hi All,
let me start by admitting I am a complete bonehead. I also couldn’t find any threads on this specifically but if there is one, please send the link.
2015 F150 super crew cab. Roughly 80k miles.
the other day I’m driving and notice a strange noise. Over the next couple days I pinpoint it to the top edge of the driver door - seems like wind is rushing in enough to “push” the weather stripping and make it “flutter”. Seemed like maybe the door was rattling a small amount on rough roads. If I pulled the interior handle, I could hold the door shut extra tight and the noise went away.
so today I go to adjust my hinge and bring the door tighter to the cab. No matter what adjustments I make (upper and lower bolts from hinge to door) The door now sags at the top rear corner of the door. So where the front door meets the back door, at the corner where the top meets the cab roofline - I know have a huge drop/gap. I cannot seem to get the door back to how it was before.
any advice on how to align the door? I know the procedure and have the FSM but nothing seems to put it in the right spot. Also- after doing all this I read that this was a common problem and could very well just have been the weather stripping and not the hinge/door alignment at all- which is why I feel like a bonehead
Old Nov 28, 2020 | 07:04 AM
IndyDog's Avatar
IndyDog
You can't be a bonehead, I was awarded that title decades ago, you can be bonehead jr. if you want but don't move in on my crown
Good luck with your quest, you'll get plenty of help here.
Old Nov 28, 2020 | 06:20 PM
Para_Bellum
Update - although this is technically a one person job according to the FSM, if you do what I did and go wild with loosening your hinge bolts, it becomes a two person job.
I had a friend come over today to help adjust and hold and tighten everything. then it was quick to get the door re-aligned to the previous position. My buddy held the door and adjusted based on how I could see it was lined up before. From the inside/door jamb and I then fine tuned the alignment then torqued the bolts and it shut perfectly. Didn’t notice as much wind noise but I do plan to reinforce the weather stripping to ensure I don’t have to deal with it in the future.
Old Nov 28, 2020 | 09:50 PM
JKBrad's Avatar
JKBrad
Do you have the keypad on your driver’s door? If so, put a couple strips of painter’s tape on it then dive around to see if the wind noise goes away.
Then you can try this trick from about a decade ago. Credit goes to a member here, EpicCowlick, who is mostly found in The Super Duty section.
Old Dec 1, 2020 | 11:33 AM
Para_Bellum
Thanks JKBrad - I came across this video before I posted my initial thread, after I already wrecked the alignment. With the door re-aligned, it seems I did get it tighter because I am not experiencing the wind noise anymore but if it comes back, I'll be trying one of these methods to strengthen the weather stripping.
Thanks again.
Old Dec 1, 2020 | 11:08 PM
tbear853's Avatar
tbear853
That door seal mod worked on our '03 Forester back in '06
jerryst
Dec 7, 2012 05:20 PM
twinpeaks
Feb 7, 2010 07:55 PM
ngng
Jan 2, 2009 07:57 PM
Desert Don
1997 - 2003 F150
Dec 10, 2006 06:47 PM
jaye
15
Feb 13, 2006 11:25 PM
