Choice between 2, 239's
Old Nov 29, 2020 | 07:05 AM
38 coupe's Avatar
38 coupe
Tell us more about those two weeks of running before you decide to put the engine out to pasture. Did you run the motor many times for short periods, say less than ten minutes each time? Did you change oil at the start of the two weeks? Did you check oil during those two weeks?
Definitely check piston stroke. Get a piston at the bottom of its stroke and drop a ruler down the bore. 3 3/4 inches is 239 Ford crank, 4 inches is 255 Mercury crank. If the camshaft appears to be in decent condition you may want to go through the pain of getting it out of the engine.
Something else that is a red flag to me is the outside of that "51 Merc" engine. The exhaust manifolds, crank pulley, water pumps, and oil pickup all look to me like Ford truck, not Mercury.
Old Nov 29, 2020 | 10:50 AM
ynot321AB1's Avatar
ynot321AB1
It still rotates and according to the book of you can put your pinky in the hole of the crank it is a mercury and if only a pencil will fit it is a ford. Pinky fits in just fine,L
If you know someone looking for this crank it would be appricated if you forwarded the info
Old Nov 29, 2020 | 12:16 PM
38 coupe's Avatar
38 coupe
I know lots of people who would like a 4" Merc crankshaft, including myself. However, if you are building a flathead you should consider it for your needs. There is no replacement for displacement, as the saying goes, and the Merc crank equipped flathead adds a bit of pep that is quite nice for most driving.
Old Nov 29, 2020 | 12:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No substitute for measuring the stroke, there are lots of shortcut ways to ID Merc cranks but too many exceptions for it to be reliable. For the crank to be worth anything it has to be in good shape and able to be ground another time.
Old Nov 29, 2020 | 01:17 PM
ynot321AB1's Avatar
ynot321AB1
Possibly a stupid question but how do y0u measure a crankshaft to determine 4"?
Old Nov 29, 2020 | 01:33 PM
38 coupe's Avatar
38 coupe
Turn the crankshaft until one of the pistons is at the bottom of its stroke, all the way down. Use a ruler to measure the distance from the top of the piston to the deck of the engine. About 4" is Merc, about 3 3/4 is Ford, anything else is questionable in an engine that looks unmodified.
Old Nov 29, 2020 | 03:25 PM
ynot321AB1's Avatar
ynot321AB1
Thanks for the information. If the second 239,(supposedly Ford Truck engine) is bad, I guess I will go for a modern engine and will advise you first if the crank is for sale.
Old Nov 30, 2020 | 01:40 PM
ynot321AB1's Avatar
ynot321AB1
My eyeballs are not calibrated but put a tape measure to it and it comes out a shade under 4" probably closer to 3 3/4"
Old Dec 1, 2020 | 02:03 PM
ynot321AB1's Avatar
ynot321AB1
R U still interested in the crank?
Old Dec 1, 2020 | 08:16 PM
38 coupe's Avatar
38 coupe
Yes, with qualifiers. I suspect shipping will be substantial. Send me a private message and we can figure it out.
Thanks, Fred
bulla
41
Oct 11, 2011 09:51 AM
chritter
Jul 16, 2008 08:48 PM
powerstroke6ltr
13
Jun 20, 2007 04:32 PM
imchrislara
Oct 16, 2006 11:51 PM
