battery tray
Old Nov 24, 2020 | 07:08 AM
symonds86's Avatar
symonds86
battery tray
Does anyone know ford offer a drivers side battery tray for a dentside, or one from a bump would fit? My supercharger put the intake tube on the opposite side it was on and now the intake wants to live where the battery is.
Old Nov 24, 2020 | 08:25 AM
originalbronco's Avatar
originalbronco
I looked into the same recently and this is the only source I found. Expensive but ready to install.
https://www.ebay.com/itm/NEW-1973-79...MAAOSwZC1Z-jrQ
Old Nov 24, 2020 | 09:04 AM
5851a's Avatar
5851a
Someone on here did a write up on using a right side on the left by separating the brackets from the tray and reversing the angles and rewelding it.
Old Nov 24, 2020 | 09:25 AM
symonds86's Avatar
symonds86
thanks guys, not sure i want to spend that much but least its available, i will try to look up that thread also
Old Nov 24, 2020 | 12:30 PM
D-rat's Avatar
D-rat
I just removed the vertical support on a new pass side one to use for my driver side battery, since my overflow tank was in the way to use it anyways. Just ran some bolts down through the bottom and pulled the inner fender liner to get nuts on them. Nice and tight.
I did find an OEM one in decent shape in a wrecking yard a while back and sold it to someone here. They're pretty rare, especially in usable condition.
Old Nov 24, 2020 | 07:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on just look at the one from the passenger side. You can cut the welds of the brackets and flip it around and re-weld. Easy and WAY cheaper than finding a OEM dvrs side one.
Old Nov 24, 2020 | 08:35 PM
symonds86's Avatar
symonds86
Sounds like that's what I will do thanks
Old Nov 24, 2020 | 08:40 PM
SlikWillie's Avatar
SlikWillie
Go lookin in the local junk yards. I found a pristine one for $5. Look for the Camper Specials.
mrpotatohead
Nov 12, 2020 09:05 AM
JoePa2
2009 - 2014 F150
Nov 4, 2020 08:48 AM
LARIAT 85
29
May 30, 2012 11:35 AM
BigDog83
Mar 29, 2008 09:29 AM
