window seal
Old Nov 23, 2020 | 04:27 PM
Ron Pauly's Avatar
Ron Pauly
window seal
My truck has a lot of wind noise and I noticed the seal on my door only goes partially around the door frame. from the door hinge to almost across the top. Is this normal? There is a cab seal that goes around that's mounted on the cab.
Old Nov 23, 2020 | 06:25 PM
Diesel_Brad's Avatar
Diesel_Brad
yes the one that is mounted to the door only goes up the angle and across the top
Old Nov 23, 2020 | 06:39 PM
Ron Pauly's Avatar
Ron Pauly
doored
I was wondering. thanks.
Old Nov 25, 2020 | 04:11 PM
seschenburg's Avatar
seschenburg
You can also compare to the other side. They should be mirrors of each other. An old trick to get them back into shape is to run some rope through them. Pick a size that's the same or a little bigger than the tube ID. Use an electrician's fish tape or a long wire to pull it through. Voila! Fresh seals.
Frisbeekev
May 4, 2020 10:24 AM
Wbruiser2
May 22, 2013 02:58 PM
Tomahawk
Apr 15, 2013 06:13 PM
OldWoodsDiesel
16
Feb 5, 2013 06:10 AM
85Blondie
Nov 5, 2012 11:22 AM
