97 E350 SD 7.3 ABS Module
Old Nov 23, 2020 | 02:25 PM
Bryan Sliger's Avatar
Bryan Sliger
Two issues I'd like your input:
1) ABS Control Module was showing as bad on code diagnostics (open circuit)
-I pulled it off and began my search in finding someone to repair, unfortunately none of the ABS rebuild specialist appear to be interested and have indicated there is not a rebuild solution.....
Has anyone bumped up against this before? It's an obsolete part at dealer, no aftermarket option......does this mean I am resorted to junkyard option with a 50/50 chance that I buy one that works?
2) Got a code for an ABS Relay......
-My van has ABS fuses (all were good) but I could not locate a relay.......even the manual did not indicate an ABS Relay
It's odd
that the code would come back as a bad relay but I cannot locate and owners manual did not indicate one.........is it hidden somewhere else besides the obvious place (fuse/relay box behind in the left front)?
See picture
Old Nov 24, 2020 | 06:07 PM
annaleigh's Avatar
annaleigh
according to this page, #1 fuse is your ABS and I do not see a relay for the abs. Even though Ford says it is obsolete, will they give you the correct part number or do you already have the part number?
https://www.autogenius.info/ford-e-3...e-box-diagram/
Old Nov 24, 2020 | 09:40 PM
Bryan Sliger
Agreed, and the #1 fuse is fine.......
I'm beginning to think the relay they are referring to is the one located inside the ABS Module
Old Nov 25, 2020 | 04:45 AM
JWA's Avatar
JWA
How did you obtain those codes and what DTC numbers were retrieved?
The only ABS relay in an E-Series is part of the 4 wheel ABS systems---your van shouldn't have that feature. I'm looking over my factory schematic for a '97 E350 and don't see anything other than the usual ABS system components which include the brake pedal switch and the brake fluid level warning switch typically located on the master cylinder.
If you're able to obtain the Ford p/n for the control module doing a Google search for it should show something. If that doesn't work you may be relegated to buying a new complete ABS control module and pump block. OR you can simply ignore the ABS light BUT keep in mind you no longer have any function of the ABS system as designed.
Old Nov 26, 2020 | 11:07 AM
95 E350's Avatar
95 E350
like the abs relay in vette's abs computer that die, i bet it's internal also. have you googled this issue? i just did and there seems to be some posts worth reading... well i hope...
Rangerforever
Jul 25, 2020 06:20 PM
npccpartsman
Jul 22, 2020 09:54 AM
TallTexan
Apr 20, 2015 07:44 PM
Blown240
1997 - 2003 F150
Jan 24, 2008 11:17 PM
Columbus
1978 - 1996 Big Bronco
Sep 6, 2004 02:27 PM
