Wiper blades
Old Nov 23, 2020 | 02:55 AM
jerryst's Avatar
jerryst
Wiper blades
My truck is ready for driving around. The wiper blades need to be replaced. What blades or replacement can I use. The blades are 12 inches long.
thanks
jerrt
Old Nov 23, 2020 | 07:43 AM
df85732's Avatar
df85732
I have the original arms on my '55 and I got mine at O'REILLY'S.
Old Nov 23, 2020 | 08:12 AM
jniolon's Avatar
jniolon
old and in the way
Jerry, I have the same problem... here's athread I started on my quest for acceptable..
https://www.ford-trucks.com/forums/1...nd-blades.html
I thought the Tricos would suit me but the attach point on the blade actually came apart as I was installing them... the search continued
After several calls to tech folks at Trico and Anco and Rain-x I found that 12-13" blades are hard to come by in newer designs, they all have the
conventional construction which builds in all the slop. I finally found an adjustable arm (11-14".. stock is 12") with the correct drum end but it had a
J-hook connection for the wiper blade.
That opened up to a variety of newer blade options
The arm I used was a Wesco 2007140 and it's available on Amazon and other places
The blade is a Bosch Evolution Beam type blade # 4813
Haven't installed them yet , still 'walkering' around with this fractured leg bone, but there is much less slop in the connections and I'm
pretty sure the beam design will wipe better than the old conventional type.
Old Nov 23, 2020 | 08:25 AM
EBEAR's Avatar
EBEAR
Just a little fyi . Rainex or similar products are invaluable . I use it on all my vehicles and quite often don't use my wipers in lighter rain .
Old Nov 23, 2020 | 01:03 PM
jerryst's Avatar
jerryst
Thanks fir all the information. I have newish wiper rams on truck. I saw 12 inch blades on rock auto. I guess I should take the arm off and go to the big chains and see if there is anything local.
thanks
jerry
Old Nov 23, 2020 | 01:53 PM
56panelford's Avatar
56panelford
Are you going to take them to the chrome shop John..?
Old Nov 23, 2020 | 04:39 PM
jniolon's Avatar
jniolon
old and in the way
no chrome, John... black blends in with the windshield rubber !
Old Nov 23, 2020 | 06:33 PM
56panelford
I have a bunch of original arms with ends like that, I'll have to go through them and see if they are better than what I have now. The re-pops on my panel are good, the ones on the pickup aren't as good..
DirtyLarry79
Aug 2, 2020 12:42 PM
ibuzzard
Oct 22, 2019 07:54 AM
psquare7575
Mar 28, 2008 05:40 PM
