1958 Hood Differences
Old Nov 23, 2020 | 01:48 AM
RossBarnard's Avatar
RossBarnard
Hi gang. I have a 58 F-100 that my boys and I are rebuilding. The hood has never latched tight. The latch clips on to the pin fine, but hood still travels up and down quite a bit. We need to get air deflector seal, hood to cowl seal, and bumper stops, adjust hinges, etc. But my question is this, the “ridge” under the hood that holds the latch doesn’t seem very rigid. It’s not soft, but I can certainly flex it a little with myhand. Our hood has just the emblem on the front. I have a good friend that has a 58 with the hood with the screen and the ford lettering on the front, and that hood has two supports that attach to the latch support, and also attach to underside of the hood. Much more solid. My question is am I missing something structural? Does anybody have this kind of hood that you could send me a pic of to compare?
Old Nov 23, 2020 | 08:32 AM
JohnNewb's Avatar
JohnNewb
Your friend has a 1959 hood.
Old Nov 23, 2020 | 01:30 PM
RossBarnard
58 hood
Thank you for that. So the structure in 58's is typically without supports?
Old Nov 23, 2020 | 02:12 PM
JohnNewb's Avatar
JohnNewb
Here are pictures of my '59. Don't have any idea what your truck has. The fact it dips down over grille likely adds rigidity. In my unbiased opinion the '58 and '57 look like they left something out.
Old Nov 23, 2020 | 02:29 PM
RossBarnard
58 hood
Thank you very much for pics! That's what my friends looks like also. I will try to find a 58 to look at to compare. Thanks again
Old Nov 23, 2020 | 02:31 PM
RossBarnard
58 Hood
Old Nov 23, 2020 | 10:26 PM
thrifty's Avatar
thrifty
this is 57. 58 hood is the same. Is this what yours look like?
Old Nov 24, 2020 | 11:11 AM
RossBarnard
58 hood
It is! But I'm curious what the underside looked like, specifically the structure that holds the hood latch. Thank you for those!
Old Nov 27, 2020 | 06:41 PM
thrifty's Avatar
thrifty
Here are a couple of pics
Old Nov 27, 2020 | 10:29 PM
thrifty's Avatar
thrifty
How is the condition of your latch? Is there any play in it? or how about a rusty area the hinge bolts to? The rubber on everything will help and adjustment will also help.
Old Nov 28, 2020 | 03:13 PM
RossBarnard
Hey there! Thanks for the pics. I found another latch that seems pretty tight. The one I have on now latches but maybe not holding too the pin as tight as I think it would. I'll get new rubber on it and make sure hinge bolts are tight. See what we can do with that. Thank you again!
abe
Dec 15, 2019 12:29 PM
HVFDFIREFIGHTER1618
Jun 6, 2019 07:01 AM
sdrob15
Nov 11, 2018 09:20 AM
Claybreaker144
Mar 13, 2018 10:20 PM
glassmanbruce
Jan 15, 2016 04:19 PM
