Low boost issue
Old Nov 21, 2020 | 08:43 PM
Conner Stevenson's Avatar
Conner Stevenson
Originally Posted by Khan
I would tend to believe it's a gauge issue. I can usually see 8-10 psi pre intercooler around 2500 rpms with a 243k stock obs turbo and leaking up pipes. Plus I only have 160/0 injectors. This is in my cummins killer tune from 1023.
Thank you for the replies! I tried adding a sig, I just can’t find where to go and fill it out. Im still learning the forum!
Old Nov 21, 2020 | 08:47 PM
TheFecalFanatic's Avatar
TheFecalFanatic
I should also add I have stand alone Isspro gauges separate from the MAP and OBD2 sensors.
Old Nov 21, 2020 | 08:50 PM
z31freakify's Avatar
z31freakify
Was low boost present before the added mods? Used IC?
Old Nov 21, 2020 | 08:56 PM
farmert's Avatar
farmert
At the top of the page, click on User Cp. When the page opens scroll down to Settings and Options. Under that heading click on edit signature. When that page opens fill out your signature the way you want it to read , then click on save signature, and you are done.
Old Nov 21, 2020 | 09:04 PM
Conner Stevenson
Yeah low boost was present before the mods. Intercooler was brand new from Banks. I’ve spent a lot of time working on this truck because I plan on keeping it running as long as possible and I can’t find the issue. I’m thinking it might be the MAP sensor or the EBP pedestal sensor. I never plugged the isolator for the EBP pedestal pigtail because I never got a CEL or even a soft code after I deleted the EBPV. But maybe the EBP sensor has gone bad and is putting the truck in limp mode. Idk, I’m at a loss.
Old Nov 21, 2020 | 09:07 PM
96 OBS's Avatar
96 OBS
Curious how does the truck feel on power?
Old Nov 21, 2020 | 09:08 PM
Conner Stevenson
Like an absolute dog. I don’t expect it to run like my 6.4, but with the injectors and tuning that I’ve done I am expecting it to wake up a little. It struggles on hills to find power too.
Old Nov 21, 2020 | 09:11 PM
96 OBS's Avatar
96 OBS
The EBV might be a good idea to delete too. Not sure how much it would affect boost pressure but I’d imagine it wouldn’t have a positive affect if it was having some kind of issues
Old Nov 21, 2020 | 09:12 PM
Conner Stevenson
I deleted it when I rebuilt the turbo and got a delete pedestal. I have had the sensor unplugged without the isolator on it though. But that soft code it throws wouldn’t put me into limp mode I don’t think.
Old Nov 21, 2020 | 09:16 PM
96 OBS's Avatar
96 OBS
Oh gotcha. Yeah that wouldn’t do it I have the same soft code. I haven’t had much experience in this area so these other experienced fellas would most likely be of more help but I’m curious if it’s something in the MAP sensor
Old Nov 22, 2020 | 06:21 AM
TheFecalFanatic
I cut my EBPV sensor wires and left them hanging for a good 6 months before getting a resistor on it. No noticeable difference on driving.
Old Nov 22, 2020 | 07:37 AM
97-psd's Avatar
97-psd
I would check the line going to the MAP sensor. It could be plugged or cracked and the sensor is not seeing pressure correctly.
Old Nov 22, 2020 | 02:12 PM
  #28
Conner Stevenson
Update for y’all. I took off my EBP sensor and have a new one in the mail from RiffRaff that’ll be in Tuesday as well as a new MAP sensor. Today I took the old EBP sensor off and it was covered in soot. BUT...the most alarming issue was that the 45 degree elbow that is welded to the bracket was completely clogged with soot! I got it cleared out and am hoping that between the new parts I have coming in and cleaning the 45 degree fitting, that I’ll have the problem rectified. I’ll keep y’all posted
Old Nov 27, 2020 | 07:40 PM
  #29
Karlow's Avatar
Karlow
Try this test, startup the truck cold with the hood up. claim in there and reach around that baby butt. If its leaking bad you will feel the exhaust. My truck failed this test four tries in a row this week! you should hit about 5 psig of boost just *****footing around on the street. I just fixed my leak. New uppies rebuilt stock turbo with an upgraded wheel and 4" exhaust. I'm running the cheep tuner with a 40 hp tune she has 240K on her clock. I adjusted waste gate valve to hold about 20lbs of boost. Today I tested her and she will hit 28lbs of boost on an on-ramp. My bet is your *** is leaking like mine was.
Old Nov 28, 2020 | 07:56 PM
  #30
Conner Stevenson
Update
Replaced EBP sensor, ICP sensor, new MAP sensor and line, fixed all boost leaks and still only about 5psi max. I’s pretty sure at this point that it’s the Edge monitor. I’m just going to get a gauge that shows boost from the MAP line. Truck does run better though. Better throttle response now. Probably from the new ICP sensor.
Conner Stevenson
15
Aug 7, 2020 08:56 AM
brandon_oma#692
40
Aug 19, 2017 10:03 PM
bigreentruck
Apr 8, 2015 12:35 AM
Insley95
16
Aug 11, 2011 12:53 PM
UP_There
Dec 4, 2008 06:10 PM
