Extra Reverse Lights?
Old Nov 21, 2020 | 11:19 PM
Killer-Bimmer's Avatar
Killer-Bimmer
Originally Posted by Ding126
Awe those are nice too... post picks when you have them in.
Old Nov 21, 2020 | 11:22 PM
Killer-Bimmer
Originally Posted by black_dog106
Thank you @Killer-Bimmer
No problem @black_dog106
Some interesting things in there that I’ll never use, but still cool to see some of the options.
Old Dec 22, 2020 | 11:05 PM
Killer-Bimmer
Finished the install today:
Ran Shielded 12awg/4ct for the feed. One is dedicated ground and the other three for aux use. Only one used at this time.
Mounted a IP67 aluminum terminal box underside of bed above the spare tire.
I think they turned out nice and they are bright as hell. Have some slight adjustments to make, but happy with the results:
Old Dec 23, 2020 | 09:02 AM
MKrenn's Avatar
MKrenn
Very nice install.... I need to do that.... When it stops snowing....
Old Dec 23, 2020 | 10:35 AM
Killer-Bimmer
Thank you, it took more time than I planned, but took my time to route cable and place everything so it was clean and out of site. I used the heat activated soldering connections and then used heat shrink over that. They worked pretty good... you have to get your heat right or you’ll burn right through them, but about 600f worked perfect!
it would be nice if the darn aux box could pull up out of the way so you can actually work on connecting wires. You can pull up and back, but had to have my son hold up and away while I completed the connection... out side the the passenger side frame has plenty of space and locations to secure cable.
I’d take some of your snow though😁
Old Dec 26, 2020 | 07:45 AM
rprice32's Avatar
rprice32
I mounted aux. lights to the back, and used one of the upfitter switches. Simple. Clean.
Old Dec 27, 2020 | 12:42 PM
Brother_Bluto's Avatar
Brother_Bluto
I ran the Zroadz LED kit with mounting brackets I used the Magnum Racks wire harness that simply plugs into the factory harness at the rear frame. A very easy and clean install. I also put in a relay and ran a single wire to the engine bay into an upfitter switch. That way the added lights come on automatically when you put in reverse... and also anytime your hit the upfitter (like parked, booking up the trailer in the dark).
chillman88
Dec 28, 2020 04:10 PM
Noah Mahan
Sep 8, 2020 08:13 AM
Arch Typo
1983 - 2012 Ranger & B-Series
Sep 3, 2018 06:47 PM
Maguey
Feb 25, 2017 09:36 PM
LaxPlaya21
Sep 28, 2014 08:49 PM
