Transmission
Old Nov 20, 2020 | 06:03 AM
Bwik's Avatar
Bwik
Transmission
Hey guys I had my transmission rebuilt about 2 months ago. And since then I've taken it back twice now fixen to be 3 times, the problem is when I would get to 50-60 mph my rpms shoot to 3k, the first time they replaced a sensor, got it back a few days later did the same thing this time they replaced the sensor again and a switch, thought that fixed it then this morning it started again, but this time it also started doing it at 30-35 mph any idea what could cause this?
Old Nov 20, 2020 | 07:04 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It would help to know what truck, engine, and transmission you have. Without that information, all I can tell you is that something is wrong.
Old Nov 20, 2020 | 07:06 AM
Bwik's Avatar
Bwik
True lol. E4od. 1995 4x4 xlt 5.8
Old Nov 20, 2020 | 08:59 AM
Mark Kovalsky
E4ODs of that era had a problem with the Manual Lever Position Sensor (MLPS - also called the TRS - Transmission Range Sensor.) it is the part on the driver's side of the trans with the wiring harness plugged into it. It can fail in a mode that the PCM cannot detect so there is no code set. When this happens you get random neutrals. Replace the MLPS.
mark224
Jan 11, 2017 08:11 AM
samsdad02
Nov 27, 2014 06:43 AM
Turfzilla
Nov 28, 2012 12:49 PM
TNT in Round Rock
Jan 24, 2012 03:58 PM
