F600 Decode
This same head was a service part replacement for the T/E heads used on 1966/67: Passenger Cars (352/390/410/428) and F100's (352), so it's possible to find these heads on 1966/67 vehicles.
Today, considering parts swapping, this head could be found on any FE engine from any year.
This is the serial number
Welcome to FTE! This forum deals with the large trucks. You will get better results here vs. being tagged on to an unrelated 5 year old thread.
F61 = F600 gas, 4x2
E = 361 2V FT V8
K = Kansas City Assembly plant
D30785 = 1968 series number
156 = 156" wheelbase
J = Red
F612 = F600 gas 23,000lbs GVWR
4B81 = Upholstrey and cab type, I don't have the complete catalog, but I think this gives you a black vinyl seat and a standard cab, based on prior decodes.
9 = New Process 541 five speed direct transmission
E** = Axle code, I can't read it. Please post and I will research it for you from prior decodes as I do not have axle codes in the catalog I downloaded.
23000 = 23,000lbs GVWR
182 3800 = 182 net HP @3800 RPM
61 = Dallas District Code
If something doesn't match, let me know and I will double check.
