Sponsored by: Real Truck
Broken spark plug
Old Nov 17, 2020 | 07:49 PM
Walter75's Avatar
Walter75
Broken spark plug
Hi
I am new to this forum. A year ago I bought a 2000 F-250 with the 5.4L 2 valve motor. I was changing my plugs yesterday. The number 7 plug broke off. The shell of the plug is in the head still. The porcelain part came out. I tried to use a square easy out but the shell won’t move. Can I drill it out and retap it or do I need to pull my head? What is your guys suggestions on this.
Thank you
Old Nov 17, 2020 | 08:25 PM
6point0's Avatar
6point0
I would think the only bet is calling a machine shop , having them drill and tap it, then helicoil it. Shouldn't be any need to pull the head.
I'm not sure if there is an option or not.
Old Nov 17, 2020 | 09:08 PM
ford390gashog's Avatar
ford390gashog
This sure sounds oddly familiar...
https://www.ford-trucks.com/forums/1...-helppppp.html
Old Nov 18, 2020 | 04:29 AM
NoelCT's Avatar
NoelCT
You need this special tool kit from Lisle. It works great. You can get it online, but Matco Tool dealers have it too. Also, you'll need access to compressed air and a long wand air-nozzle. If you're anywhere near CT, you're welcome to borrow my Lisle spark-plug tool kit.
https://www.summitracing.com/parts/l...oaAtQlEALw_wcB
,Noel.
Old Nov 18, 2020 | 05:55 AM
projectSHO89's Avatar
projectSHO89
,Noel.
Wrong. That tool is for the newer 3V engines.
Using a Helicoil or one of the cheap "fixes" is ill-advised. They fail with Congress-like regularity on these engines resulting in blown plugs.
....snip....
thread-stuck-helppppp.html
Lol...
Old Nov 19, 2020 | 07:51 AM
Brahms's Avatar
Brahms
Check the engine subforum. Lotz of help there, which I have used both for a '97 Expedition and a 2008 Navigator.
Old Nov 19, 2020 | 09:31 AM
Model a ford's Avatar
Model a ford
Have you been using an impact to remove plugs, and putting a “dab” of never- seize on plug threads, then torquing them into place, for new ones.
I have never had trouble since I started using an impact, “use it gently”, I think the impacts shake the carbon loose from the one or two threads that actually go into combustion chamber. Just saying!!
Old Nov 19, 2020 | 01:10 PM
99powerstrokedF250's Avatar
99powerstrokedF250
The one time I looked into doing plugs on my wife's '08 Expedition (IIRC a 3v motor), the recommended procedure to change the plugs involved getting the motor up to operating temperature, then using an impact to remove the plugs. The higher temps + impact apparently makes everything work easier.
I had no desire to work on a hot motor, so I had the dealer do it.
Old Nov 19, 2020 | 02:50 PM
Fatz29708's Avatar
Fatz29708
soak the area with Kroil for a day or three and see if you can wiggle it out by hand. If it where me I'd tap it down a bit before pulling up but, I've been down this road before and know the consequences of making stupid decisions.
Another option is to soak for a day with kroil, tap is very slightly down, then crank her up and see if the engine will push it out... Oh forgot to say, maybe put a blanket or something to stop it from customizing your hood.
Old Nov 19, 2020 | 10:21 PM
Walter75's Avatar
Walter75
Hi Guys
I am going try to get this the spark plug shell out this weekend. I let you know how it goes.
thanks
Old Nov 20, 2020 | 08:48 AM
alloro's Avatar
alloro
Use a reverse spiral one and don't spare the muscle. Using an impact gun would be a bonus.
Old Nov 20, 2020 | 08:59 AM
Walter75's Avatar
Walter75
Hi Alloro
You think that will work to get the shell out? I don’t have an impact. I just don’t want drill it out.
thanks
Old Nov 22, 2020 | 09:20 AM
alloro's Avatar
alloro
I prefer the spiral ones over the square ones because to me it seems the more I torque it the more it bites.
Old Nov 23, 2020 | 07:31 AM
99powerstrokedF250
The spiral ones DO bite harder. The biggest drawback is they also tend to break easier so you've got to make sure you're square to whatever you're removing.
Old Dec 12, 2020 | 10:04 AM
Walter75's Avatar
Walter75
Hi Guys
i wanted to give you an update on my truck. I got the broken shell out of the head. I got the new plug in . The truck is back on the road. Now I get to tackle the valve cover gaskets.
thanks
