What to do with air sensor
Old Nov 15, 2020 | 04:19 PM
milkstake's Avatar
milkstake
Hello, been here for a bit, finally getting ready to dig into my 97 cclb. When I bought this truck, the air box had been removed and now just has a cone filter. The sensor is just hanging out where the box used to be.
If these sensors go bad, would it throw a code?
do I need it?
What should I do with it if it is needed?
Sensor doesn't look like it is in good shape
Thanks in advance
Old Nov 15, 2020 | 05:42 PM
BuddyBarnes's Avatar
BuddyBarnes
I think most just lay it on the fender like it is. I did years ago and no problem. I do not recall it causing a code when I have pulled codes on my truck. FYI I have never seen a air filter like that.
Old Nov 15, 2020 | 05:45 PM
BuddyBarnes
I have also run my truck with and without this sensor and could tell no difference.
Old Nov 16, 2020 | 05:28 AM
milkstake's Avatar
milkstake
Thanks for the response, yeah, filter is different for sure. I think id prefer the stock set up, I here mixed things about these filters on powerstrokes
Old Nov 16, 2020 | 06:41 AM
JayTheCPA's Avatar
JayTheCPA
That filter looks like it is collapsing inward from vacuum. If so, it is a restriction and a better flowing filter should replace it.
Old Nov 16, 2020 | 10:13 AM
knottyrope's Avatar
knottyrope
i thought the same and looks like a KnN filter which have been known to let in too much dust
my sensor is dangling to side
Old Nov 16, 2020 | 10:21 AM
BuddyBarnes
Search 6637 filter. I have been running one for years and have no regret.
Old Nov 16, 2020 | 11:23 AM
Hit Man X's Avatar
Hit Man X
You also seem to have the early switch on the master cylinder. There is a TSB recall out for it, I made a post for this item with the Ford part number.
Also, Ford will do it free if you want too.
Old Nov 16, 2020 | 02:25 PM
milkstake's Avatar
milkstake
The few pictures I've posted of this truck seem to get comments, makes me a little nervous to post more pictures lol. Thanks for the feedback fellas, ill start a build thread soon and then you guys can pick it apart lol
The filter is made by spectrum.
This is the only 7.3 I have had so I dont have a lot to compare it to, its hard to tell whats not there and what is supposed to be there. Finally about to start working on it after 2 years
Old Nov 16, 2020 | 02:51 PM
knottyrope's Avatar
knottyrope
take more pics and we can tell you more
Old Nov 17, 2020 | 11:41 AM
Hit Man X's Avatar
Hit Man X
Lots of comedy happens to vehicles after 25 years. Check my build thread to see where mine started...
Old Nov 17, 2020 | 01:18 PM
knottyrope's Avatar
knottyrope
worked on uncles Cadillac years ago for an auto antennae issue
took out the fender liner to get at it to replace it and thats when i noticed something shiny down there.
A GM combo wrench 1/2 - 9/16 sitting in there.
He had a strange noise hitting big bumps the dealer never could find the cause of.
Old Nov 17, 2020 | 09:45 PM
96 OBS's Avatar
96 OBS
Sounds like I must’ve been in that car at some point
towsrus
Dec 1, 2010 10:57 AM
1999SuperD
Apr 6, 2010 04:36 PM
TheTowingCowboy
Apr 20, 2007 11:14 AM
otpracer100
Jan 24, 2006 09:52 PM
sdpj
Jan 1, 2005 12:41 AM
