Mason Dump Hydraulic Problem
Old Nov 14, 2020 | 10:43 AM
joel gerardi's Avatar
joel gerardi
I have an f350 mason dump with a peebody dump. Every time I let the dump body down it spews hydraulic fluid out of the reservoir fill cap. If I let it down while it is still in PTO it seems worse and if there is any weight in the bed it definitely worse. The fluid also seems to be aerated with bubbles.
Im thinking that the pump might have a bad seal that is allowing it to take on air. Im not sure what is going on other than it is all but disabling the truck because everytime I use the dump, it makes a huge mess.
Any thoughts?
JG
Old Nov 14, 2020 | 11:58 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It sounds like it is overfilled. That fluid has to go somewhere when the piston retracts.
Old Nov 14, 2020 | 12:55 PM
yardbird's Avatar
yardbird
If you have a hydraulic ram type lift, it sounds like there is air in the system. There should be a bleeder at the top of the ram. Lift the bed up about two feet and crack the bleeder until solid fluid comes out. This may take a few tries. Sounds like the air is compressing as the unit lifts, and expands when coming down.
Old Nov 14, 2020 | 04:41 PM
Diesel_Brad's Avatar
Diesel_Brad
Sounds overfilled to me as well
Old Dec 3, 2020 | 09:11 AM
joel gerardi
I dont think it is overfilled. It goes up pretty slowly, when it lowers it dumps fluid out. Once it dumps the fluid it wont go all the way up (due to a lack of fluid im assuming). I did read that the line from the tank to the pump could have a blockage causing the pump to draw in some air. Then once the cylinder is retracting it is pushing all of the aerated fluid back in to the tank.
any thoughts on that?
JG
Sgtusmc98
Sep 15, 2019 08:20 PM
eriklane
Nov 2, 2010 09:44 PM
dave87
Oct 2, 2009 08:01 AM
just-n-time
Jul 29, 2008 10:56 PM
Jeffman
1978 - 1996 Big Bronco
Oct 13, 2005 02:19 PM
